[Qgis-user] Color Scale Bar does not find the colour table or QML file
Benoit de Cabissole
benoit at exigesa.com
Tue Oct 12 22:57:05 PDT 2010
Hi Agus,
Thanks for the report.
I've modified the code so that I hope it will work under Ubuntu as well.
Could you please try again with the latest version (0.3.0)?
Best regards,
Benoit
On 12/10/2010 20:29, Agustin Lobo wrote:
> Hi!
> I've tried to use the plugin Color Scale Bar under ubuntu 9.04 (qgis
> 1.5 from binaries). While
> this plugin works fine under windows XP, under ubuntu I've found:
> 1. It would seem that the plugin requires a *.tbl or *.qml file for
> the "Open a colour table or QML file" dialog, yet the file created by
> "1-band raster colour table" is a *.txt file
> 2. If you select the file created by "1-band raster clour table", a
> second dialog prompts for the file again. If you cancel this second
> dialog the file initially selected appears in the general Dialog of
> the plugin, but when you click "Create" an error message is displayed:
> "You have to first select file".
> 3. Same behaviour for *.qml files
> I've filled a ticket, wish to tell tha author as well but he/she is
> not mentioned in the doc of the plugin.
> Thanks
> Agus
> Qgis-user mailing list
