[Qgis-user] 'snapSegmentWithContext' with Quantum Navigator
Martin Dobias
wonder.sk at gmail.com
Mon Oct 18 11:05:51 PDT 2010
Hi Joe
the Quantum Navigator project has been dead for several years, so such
errors from old API calls can jump at you from any corner. I'm quite
busy nowadays, so I guess you're on your own :-(
btw. for your particular error: try to have a look at the
QgsVectorLayer class. There are other snap*() functions which I
believe have replaced that snapSegmentWithContext method.
Regards
Martin
On Sun, Oct 17, 2010 at 5:54 PM, Joe Larson <joelarso at gmail.com> wrote:
> Hello All,
> I'm trying to get Quantum Navigator
> http://www.mapserver.sk/~wonder/qnavigator/ going on Maverick Meerkat, built
> against QGIS trunk.
> jef on IRC helped me with the API switch past QGIS 1.0, which got me past
> the initial 'make' compile. I got through ./dgbuild and can run
> qnavigator.py, but when I am in the 'Routing' tab and pass a Start event
> from(to) the map.
> seems 'snapSegmentWithContext' is stumping me:
> Traceback (most recent call last):
> File "/home/joe/dev/qnavigator/python/gui/tools.py", line 21, in
> canvasReleaseEvent
> self.callback(self.pos)
> File "/home/joe/dev/qnavigator/python/gui/main.py", line 257, in gotStart
> pnt = self.routing.setStart(pos)
> File "/home/joe/dev/qnavigator/python/routing/routing.py", line 159, in
> setStart
> self.start = self.layer.findNearestPoint(point)
> File "/home/joe/dev/qnavigator/python/routing/routing.py", line 84, in
> findNearestPoint
> (result, point, vertexIndex, fid, geom) =
> self.snapSegmentWithContext(point, RoutingLayer.tolerance)
> AttributeError: 'RoutingLayer' object has no attribute
> does anyone have any advice? i tried adjusting the tolerance, researching
> besides that...thank you,
> ~joe
> Qgis-user mailing list
