[Qgis-user] CSWclient is available
Paolo Cavallini cavallini at faunalia.it
Thu Oct 21 10:49:48 PDT 2010
Il 21/10/2010 19:29, Annina Hirschi Wyss ha scritto:
> You could try the: http://www.geocat.ch/geonetwork/srv/eng/csw? It's with the swiss ISO profile, but should normally be OGC compliant (at least with the default outputSchema).
I confirm: anything I tried works. Unfortunately there are no WMS and downloadable
data, so we cannot test all functions. I suggest to add it to the list of default
servers.
One suggestion: why not adding the option of searching only services of a certain
type (e.g. dataset etc.)?
Also, it would be good if pressing return after digitizing the search string would
activate the search.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
