[Qgis-user] plugin to import raw binary raster data
Agustin Lobo alobolistas at gmail.com
Fri Oct 22 02:12:04 PDT 2010
I've  tested including a resources.py file and the plugin works (the
menu opens, have
not imported anything yet).
Agus
2010/10/22 Giuseppe Sucameli <sucameli at faunalia.it>:
> Hi guys,
> On Fri, Oct 22, 2010 at 10:25 AM, Agustin Lobo <alobolistas at gmail.com>
> wrote:
>> Which module is the one actually needed?
> it's a plugin's missing module. You don't need to install anything.
> To Ghishlain:
> could you update your plugin either removing "import resources" (line 27)
> from
> the RawRasterFileImport.py module or creating a resources.py empty file?
> Cheers.
>> 2010/10/21 Ghislain Picard <ghislain.picard at lgge.obs.ujf-grenoble.fr>:
>> > A new plugin is available to help importing raw binary raster data into
>> > QGIS.
>> > The plugin creates a VRT file from information about the file structure
>> > given by the user. The VRT file can then be opened with QGis as any
>> > other
>> > raster format.
>> > Ghislain
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
