[Qgis-user] plugin to import raw binary raster data
Ghislain Picard ghislain.picard at lgge.obs.ujf-grenoble.fr
Sat Oct 23 07:34:10 PDT 2010
corrected in version 0.2.
Thanks for your tests.
Ghislain
On 10/22/2010 11:12 AM, Agustin Lobo wrote:
> I've  tested including a resources.py file and the plugin works (the
> menu opens, have
> not imported anything yet).
> Agus
> 2010/10/22 Giuseppe Sucameli<sucameli at faunalia.it>:
>> Hi guys,
>> On Fri, Oct 22, 2010 at 10:25 AM, Agustin Lobo<alobolistas at gmail.com>
>> wrote:
>>> Which module is the one actually needed?
>> it's a plugin's missing module. You don't need to install anything.
>> To Ghishlain:
>> could you update your plugin either removing "import resources" (line 27)
>> from
>> the RawRasterFileImport.py module or creating a resources.py empty file?
>> Cheers.
>>> 2010/10/21 Ghislain Picard<ghislain.picard at lgge.obs.ujf-grenoble.fr>:
>>>> A new plugin is available to help importing raw binary raster data into
>>>> QGIS.
>>>> The plugin creates a VRT file from information about the file structure
>>>> given by the user. The VRT file can then be opened with QGis as any
>>>> other
>>>> raster format.
>>>> Ghislain
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giuseppe Sucameli
