[Qgis-user] PostGIS 2 SHP
Ricardo Bayley ricardo.bayley at gmail.com
Sat Oct 23 10:28:27 PDT 2010
Thanks Andrea !
Using ogr2ogr does work properly.
2010/10/23 Andrea Peri 2007 <aperi2007 at gmail.com>
> Hi fellows,
>> I am loading a postgis Layer and then saving it to shapefile. Job gets
>> done.
>> BUT, data type character varying, or character, is always set to 255 CHAR
>> in
>> the shapefile.
>> Therefore, my dbf ends up being a huge table. Is this some bug or I am
>> simply doing something wrong ?
>> Any thoughts appreciated
>> Ricardo
> The exporting procedure (save as) of qgis do this.
> But if you use og2ogr (from gdal) to export from postgres to shapefile the
> string field was exactly the needed.
> I test with the trunk version of gdal.
> Regards,
> Andrea Peri
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101023/f24024c1/attachment.html>
