[Qgis-user] PostGIS 2 SHP
Ricardo Bayley
ricardo.bayley at gmail.com
Tue Oct 26 17:46:36 PDT 2010
Hi Andrea,
How can I set the encoding when exporting from postgres to SHP using the OGR
Ricardo
2010/10/23 Ricardo Bayley <ricardo.bayley at gmail.com>
> Thanks Andrea !
> Using ogr2ogr does work properly.
> 2010/10/23 Andrea Peri 2007 <aperi2007 at gmail.com>
> Hi fellows,
>>> I am loading a postgis Layer and then saving it to shapefile. Job gets
>>> done.
>>> BUT, data type character varying, or character, is always set to 255 CHAR
>>> in
>>> the shapefile.
>>> Therefore, my dbf ends up being a huge table. Is this some bug or I am
>>> simply doing something wrong ?
>>> Any thoughts appreciated
>>> Ricardo
>> The exporting procedure (save as) of qgis do this.
>> But if you use og2ogr (from gdal) to export from postgres to shapefile the
>> string field was exactly the needed.
>> I test with the trunk version of gdal.
>> Regards,
>> Andrea Peri
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101026/9ddc1c1a/attachment.html>
