[Qgis-user] Re: Overview (inset map ) in map composer
Lionel Roubeyrie
lionel.roubeyrie at gmail.com
Thu Oct 28 00:39:32 PDT 2010
HI,
and a select zoom area button in the print composer would be a great
thing too, setting manually extents is not as simple as in the map
canvas.
cheers
2010/10/28 Alister Hood <alister.hood at synergine.com>:
> Hi guys,
> There is a feature request for adding the map from the overview pane to
> the composer:
> https://trac.osgeo.org/qgis/ticket/2348
> That person is after essentially the same result as you Marco, but they
> seem to have forgotten that the extent of the map view is almost always
> at least slightly different from the extent of the detail map in the
> print composer. So the map extent rectangle shown in the overview would
> be wrong.
> It might be more flexible anyway to have a plugin add a rectangle to a
> normal map canvas on the print composer, showing the extents of another
> map canvas. I think this would be a popular feature - does anyone know
> how feasible it would be?
> I imagine the other problem mentioned in that ticket (the difficulty
> around preserving/changing the layers shown on a map canvas in the
> composer) is something that should be addressed separately.
> Regards,
> Alister
>> Date: Wed, 27 Oct 2010 15:42:10 +0000 (UTC)
>> From: Marco Tuckner <marcotuckner at public-files.de>
>> Subject: [Qgis-user] Re: Overview (inset map ) in map composer
>> To: qgis-user at lists.osgeo.org
>> Message-ID: <loom.20101027T174030-962 at post.gmane.org>
>> Content-Type: text/plain; charset=us-ascii
>> > You can simply add another map to the canvas, and then set the
>> extents and
>> scale to only cover your area of interest.
>> Yes.
>> But how do I make them dynamically zoom and also display an extend
>> rectangle on
>> the overview map showing th extend of the detailed map?
>> Thanks for following up.
>> Regards,
>> Marco
> Qgis-user mailing list
Lionel Roubeyrie
http://youarealegend.blogspot.com
