[Qgis-user] Re: Overview (inset map ) in map composer
Alister Hood alister.hood at synergine.com
Wed Oct 27 15:47:09 PDT 2010
Hi guys,
There is a feature request for adding the map from the overview pane to
the composer:
https://trac.osgeo.org/qgis/ticket/2348
That person is after essentially the same result as you Marco, but they
seem to have forgotten that the extent of the map view is almost always
at least slightly different from the extent of the detail map in the
print composer.  So the map extent rectangle shown in the overview would
be wrong.
It might be more flexible anyway to have a plugin add a rectangle to a
normal map canvas on the print composer, showing the extents of another
map canvas.  I think this would be a popular feature - does anyone know
how feasible it would be?
I imagine the other problem mentioned in that ticket (the difficulty
around preserving/changing the layers shown on a map canvas in the
composer) is something that should be addressed separately.
Regards,
Alister
> Date: Wed, 27 Oct 2010 15:42:10 +0000 (UTC)
> From: Marco Tuckner <marcotuckner at public-files.de>
> Subject: [Qgis-user] Re: Overview (inset map ) in map composer
> To: qgis-user at lists.osgeo.org
> Message-ID: <loom.20101027T174030-962 at post.gmane.org>
> Content-Type: text/plain; charset=us-ascii
> > You can simply add another map to the canvas, and then set the
> extents and
> scale to only cover your area of interest.
> Yes.
> But how do I make them dynamically zoom and also display an extend
> rectangle on
> the overview map showing th extend of the detailed map?
> Thanks for following up.
> Regards,
> Marco
