[Qgis-user] [solved] QGIS MapServer SVG
Horst Düster
horst.duester at kappasys.ch
Mon Sep 6 00:54:12 PDT 2010
Hi Marco
Thank you very much. I use new generation symbology and your hints
solved my problem when I store my svg files in
$CMAKE_INSTALL_PREFIX/share/qgis/svg
But when I store the svg files in a folder like
$CMAKE_INSTALL_PREFIX/share/qgis/svg/mySymbols
it doesn't work.
Greetings from Barcelona
Horst
Am 05.09.2010 12:32, schrieb Marco Hugentobler:
> Hi Horst
> Which renderer do you use (old symbology marker, new symbology svg marker or
> any other)?
> new symbology:
> If you build with qgis trunk, the mapserver looks for svg symbols at the QGIS
> install path ($CMAKE_INSTALL_PREFIX/share/qgis/svg). So normally, it should
> not be necessary to move the svg files.
> old symbology:
> If you are using old symbology, the absolute svg pathes are in the project file
> (assuming you save with 'absolute paths' in project properties).
> Regards,
> Marco
> Am Samstag, 4. September 2010, um 17.32:57 schrieb Horst Düster:
>> Hi
>> I have created a QGIS project with some new SVG symbols. Now I want to
>> serve this project as a WMS via QGIS MapServer, but all SVG symbols
>> don't appear in the resultant WMS image. Now I'm in doubt where I have
>> to put my SVG files on my server.
>> Any hint will be appreciated.
>> Horst
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
