AW: AW: Re: [Qgis-user] building qgis on mac os x
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue Sep 7 00:34:34 PDT 2010
Hi
I changed ARCHS to x86_64 only and it works. Thanks!
regards
Stefan
----- Originalnachricht -----
Von: "William Kyngesburye" <woklist at kyngchaos.com>
Gesendet: Sam, 4.9.2010 23:26
An: "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Betreff: Re: AW: Re: [Qgis-user] building qgis on mac os x
On Sep 4, 2010, at 3:39 PM, Ziegler Stefan wrote:
> ld: warning: in /Users/stefan/Develop/src/qgis_trunk/mac/xcode/build/snow/Release/Qgis.app/Contents/MacOS/lib/libqwt.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
> Undefined symbols:
> "QwtAbstractScaleDraw::setScaleDiv(QwtScaleDiv const&)", referenced from:
> QwtPolarGrid::updateScaleDiv(QwtScaleDiv const&, QwtScaleDiv const&, QwtDoubleInterval const&)in qwt_polar_grid.o
> It seems that there is something wrong with my Qwt stuff. How can I check if all is installed correctly? And can I build Qgis without PyQwt/Qwt support?
It's possible you compiled Qwt 64bit-only (very likely, since 64bit is default on Snow for all but the first core solo/duo Macs). Then you left Qgis at the default 32+64bit (you changed SDKSYS to "snow", and left ARCHS at the default "i386 x86_64").
Hmmm.... maybe I should change those defaults. I set up the xcode project with packaging in mind, where you would want to cover all supported variations of a system version, ie "universal". But really, one-off builds by users will most likely be for the system they're building on. And the Qgis installation instructions are single-arch.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
