[Qgis-user] SDA4P: problem with rJava (iplots)
Agustin Lobo
alobolistas at gmail.com
Tue Sep 7 06:30:52 PDT 2010
Hi!
I have installed all R components for SDA4P but if I select
Components/R packages
package iplots is selected as missing.
Nevertheless, if I open an R console I can load iplots with no problem-
Also, if I run qgis from a terminal, I get:
Loading required package: rJava
Error : .onLoad failed in loadNamespace() for 'rJava', details:
call: dyn.load(file, DLLpath = DLLpath, ...)
error: unable to load shared library
'/usr/local/lib/R/site-library/rJava/libs/rJava.so':
libjvm.so: cannot open shared object file: No such file or directory
Error: package 'rJava' could not be loaded
LoadRlib | loadIplot | iplots load error.
Loading required package: gstat
LoadRlib | loadAutomap | automap package loaded.
So it seems that the problem is rJava, but I can require(rJava) in a R session
with no problem. Could it be that the test is not correctly done or do
I have a problem
on my side?
Thanks!
Agus
