[Qgis-user] Re: SDA4P: problem with rJava (iplots)
Volkan Kepoglu
vkepoglu at gmail.com
Wed Sep 8 13:26:58 PDT 2010
I installed ubuntu 10.04 to setup similar environment to replicate the
error. I am so successful for environment that the same error (Error:
package 'rJava' could not be loaded) also occured in my new environment, but
not fixing the error. :-)
rJava (or iplots) can be loaded in r-cran but not in my plug-in for now,
sorry, but if i could find the solution, I will let you know.
volkan.
On Tue, Sep 7, 2010 at 4:30 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Hi!
> I have installed all R components for SDA4P but if I select
> Components/R packages
> package iplots is selected as missing.
> Nevertheless, if I open an R console I can load iplots with no problem-
> Also, if I run qgis from a terminal, I get:
> Loading required package: rJava
> Error : .onLoad failed in loadNamespace() for 'rJava', details:
> call: dyn.load(file, DLLpath = DLLpath, ...)
> error: unable to load shared library
> '/usr/local/lib/R/site-library/rJava/libs/rJava.so':
> libjvm.so: cannot open shared object file: No such file or directory
> Error: package 'rJava' could not be loaded
> LoadRlib | loadIplot | iplots load error.
> Loading required package: gstat
> LoadRlib | loadAutomap | automap package loaded.
> So it seems that the problem is rJava, but I can require(rJava) in a R
> session
> with no problem. Could it be that the test is not correctly done or do
> I have a problem
> on my side?
> Thanks!
> Agus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100908/07fdf97c/attachment.html>
