[Qgis-user] QGIS & windows xp 64 bit
Noli Sicad
nsicad at gmail.com
Sat Sep 11 16:58:02 PDT 2010
If you can't run iTunes, you are running Window XP 64. It is
problematic version of Windows XP, very software runs in Window XP 64
version.
If you have plenty of time you run this Windows XP 64 version since
you are just looking for drivers most of the time. You don't install
prepackage software for Windows XP 64, you must compile it.
Windows 7 64 is entirely different from Windows XP 64.
I got a lot of problems in uisng Windows XP 64. It is not worth using it.
Noli
On 9/12/10, Brian J. Torreano <qgis at btdarters.com> wrote:
> Hi all,
> I'm running Windows XP and was hoping to install QGIS 1.5.0. How do you
> find out if your machine is 32- or 64-bit? I can't seem to find it in the
> control panel.
> Brian
> Brian J. Torreano - Owner
> BTDarters
> American Native Fish for
> your aquarium...and more!
> Web: http://www.btdarters.com
> Phone: (262) 268-7489
> ----- Original Message -----
> From: "Giovanni Manghi" <giovanni.manghi at gmail.com>
> To: "Colin Broughton" <broughton.colin at gmail.com>
> Cc: "Qgis User List" <qgis-user at lists.osgeo.org>
> Sent: Saturday, September 11, 2010 11:03 AM
> Subject: Re: [Qgis-user] QGIS & windows xp 64 bit
>> On Sat, 2010-09-11 at 17:49 +1000, Colin Broughton wrote:
>>> Hi,
>>> QGIS 1.5 installs and works perfectly for me on Windows 7 64bit.
>>> Hopefully this information is useful.
>> Hi,
>> yes under both Seven 32 and 64 bit I don't have problems either. The
>> message
>> the application failed to initialize properly (0xc0150000)
>> shows under some XP 32 (and one XP 64 bit) installations and that is
>> weird because in some other xp 32 bit computers I don't have any problem
>> at all.
>> For this reason I cannot test properly qgis 1.5 under XP 64 bit, that is
>> the reason that made me start this thread.
>> If someone can confirm to me that it works fine as it works under Seven
>> 64 bit I would appreciate.
>> thanks
>> cheers
>> -- Giovanni --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
