[Qgis-user] QGIS & windows xp 64 bit
Noli Sicad
nsicad at gmail.com
Sat Sep 11 16:59:46 PDT 2010
It should read.
... very few software runs in Windows XP 64 edition.
Noli
On 9/12/10, Noli Sicad <nsicad at gmail.com> wrote:
> If you can't run iTunes, you are running Window XP 64. It is
> problematic version of Windows XP, very software runs in Window XP 64
> version.
> If you have plenty of time you run this Windows XP 64 version since
> you are just looking for drivers most of the time. You don't install
> prepackage software for Windows XP 64, you must compile it.
> Windows 7 64 is entirely different from Windows XP 64.
> I got a lot of problems in uisng Windows XP 64. It is not worth using it.
> Noli
> On 9/12/10, Brian J. Torreano <qgis at btdarters.com> wrote:
>> Hi all,
>> I'm running Windows XP and was hoping to install QGIS 1.5.0. How do you
>> find out if your machine is 32- or 64-bit? I can't seem to find it in
>> the
>> control panel.
>> Brian
>> Brian J. Torreano - Owner
>> BTDarters
>> American Native Fish for
>> your aquarium...and more!
>> Web: http://www.btdarters.com
>> Phone: (262) 268-7489
>> ----- Original Message -----
>> From: "Giovanni Manghi" <giovanni.manghi at gmail.com>
>> To: "Colin Broughton" <broughton.colin at gmail.com>
>> Cc: "Qgis User List" <qgis-user at lists.osgeo.org>
>> Sent: Saturday, September 11, 2010 11:03 AM
>> Subject: Re: [Qgis-user] QGIS & windows xp 64 bit
>>> On Sat, 2010-09-11 at 17:49 +1000, Colin Broughton wrote:
>>>> Hi,
>>>> QGIS 1.5 installs and works perfectly for me on Windows 7 64bit.
>>>> Hopefully this information is useful.
>>> Hi,
>>> yes under both Seven 32 and 64 bit I don't have problems either. The
>>> message
>>> the application failed to initialize properly (0xc0150000)
>>> shows under some XP 32 (and one XP 64 bit) installations and that is
>>> weird because in some other xp 32 bit computers I don't have any problem
>>> at all.
>>> For this reason I cannot test properly qgis 1.5 under XP 64 bit, that is
>>> the reason that made me start this thread.
>>> If someone can confirm to me that it works fine as it works under Seven
>>> 64 bit I would appreciate.
>>> thanks
>>> cheers
>>> -- Giovanni --
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
