[Qgis-user] Projection of Shapefile export
Micha Silver
micha at arava.co.il
Sat Sep 18 23:35:19 PDT 2010
Micha Silver wrote:
> Brett Adams wrote:
>> Micha,
>> I've attached csv data for importing and all shape files exported.
>> I've added comments into your prior email also.
> Hi Brett:
> I do indeed see a problem exporting to the AGD84 CRS. I get a
> "Latitude or Longitude exceeds limits" error. This happens when the
> global CRS is set to WGS84 (which is the default in QGIS). Attached is
> a screen shot of the error.
> Here's how to overcome the problem: Change your Global CRS to AGD84
> zone 51 (BTW, that's EPSG code 20351). This is done in the
> Settings->Options->CRS dialog window. Now re-import the csv file and
> then save as shapefile and you should be able to select the AGD84 CRS
> and have it saved correctly.
> Alternatively, if you don't want to change the global CRS setting, you
> can select (in the same Settings->Options-CRS window) to "Prompt for
> CRS". Then when you import the csv you'll be asked to specify the
> correct CRS for the points, You again select AGD84 and all should be
> well.
> Cheers,
> Micha
And just to complete the picture, Jurgen reminded me that in recent
versions there's a setting for each layer to set what CRS it is. This is
found in the Layer->properties window, General tab. Click on the button
"Specify CRS" and choose the correct coordinate system. You can do this
also for a delimited text file layer. Then export to shapefile works as
you'd expect..
Micha
