[Qgis-user] Projection of Shapefile export
Brett Adams
badams.spinifex at gmail.com
Sun Sep 19 19:21:07 PDT 2010
Micha,
Sorry but I can't get your suggestions to work. I tried this a couple of
times but it fails every time.
Settings->Options-CRS window is already set to "Prompt for CRS"
Tried changing the global to AGD84 / AMG zone 51, when I reopen the
window its set to AGD66 so this setting is not holding.
When I reimport the the CSV file the default is still WGS84, despite the
global been set to AGD84 (or is it AGD66, I can't be sure). Again I
select AGD84.
Layer > Properties > Specify CRS comes up as AGD66. Changed it to AGD84
When I export the layer, I'm again asked to specify the projection, AGD84
Exported *.prj file still has a datum of "D_unknown". Upon import of the
shape file, my version of QGIS will now default this to AGD84 however as
the *.prj file is wrong it no good to anyone else.
The only real work around I have so far is to delete the *.prj file and
then specify the projection on import.
On 19/09/2010 2:35 PM, Micha Silver wrote:
> Micha Silver wrote:
>> Brett Adams wrote:
>>> Micha,
>>> I've attached csv data for importing and all shape files exported.
>>> I've added comments into your prior email also.
>> Hi Brett:
>> I do indeed see a problem exporting to the AGD84 CRS. I get a
>> "Latitude or Longitude exceeds limits" error. This happens when the
>> global CRS is set to WGS84 (which is the default in QGIS). Attached
>> is a screen shot of the error.
>> Here's how to overcome the problem: Change your Global CRS to AGD84
>> zone 51 (BTW, that's EPSG code 20351). This is done in the
>> Settings->Options->CRS dialog window. Now re-import the csv file and
>> then save as shapefile and you should be able to select the AGD84 CRS
>> and have it saved correctly.
>> Alternatively, if you don't want to change the global CRS setting,
>> you can select (in the same Settings->Options-CRS window) to "Prompt
>> for CRS". Then when you import the csv you'll be asked to specify
>> the correct CRS for the points, You again select AGD84 and all should
>> be well.
>> Cheers,
>> Micha
> And just to complete the picture, Jurgen reminded me that in recent
> versions there's a setting for each layer to set what CRS it is. This
> is found in the Layer->properties window, General tab. Click on the
> button "Specify CRS" and choose the correct coordinate system. You can
> do this also for a delimited text file layer. Then export to
> shapefile works as you'd expect..
Brett Adams
Spinifex Geophysics
0438 861 974
SKYPE:brettadams_spinifex
