[Qgis-user] Projection of Shapefile export
Jürgen E. Fischer
jef at norbit.de
Mon Sep 20 13:42:58 PDT 2010
Hi Brett,
On Mon, 20. Sep 2010 at 22:11:17 +0800, Brett Adams wrote:
> Actually, this is worse than I thought. QGIS is not recognising AGD84 or
> GDA94. The data comes in but isn't attributed a CRS so defaults to WGS84.
> If you import the text file as AGD84, then again as GDA94, there should be
> approx 195m separation. QGIS plots them in exactly the same place.
But have have set a specific projection in your project properties and enabled
on-the-fly projection? Otherwise QGIS won't reproject anything.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
