[Qgis-user] Projection of Shapefile export
Brett Adams
badams.spinifex at gmail.com
Mon Sep 20 17:21:34 PDT 2010
Enabling "On-the-fly projection" does make a small difference but the
offset should be approx 195-200m. I get 12m.
On 21/09/2010 4:42 AM, Jürgen E. Fischer wrote:
> Hi Brett,
> On Mon, 20. Sep 2010 at 22:11:17 +0800, Brett Adams wrote:
>> Actually, this is worse than I thought. QGIS is not recognising AGD84 or
>> GDA94. The data comes in but isn't attributed a CRS so defaults to WGS84.
>> If you import the text file as AGD84, then again as GDA94, there should be
>> approx 195m separation. QGIS plots them in exactly the same place.
> But have have set a specific projection in your project properties and enabled
> on-the-fly projection? Otherwise QGIS won't reproject anything.
> Jürgen
Brett Adams
Spinifex Geophysics
0438 861 974
SKYPE:brettadams_spinifex
