[Qgis-user] Points2One bug
aaron at campusactivism.org
Sat Sep 25 14:28:21 PDT 2010
I sent this to the list. I think you created the Points2One plugin, so I'm sending you a copy. I'd appreciate any help!
I'm trying to import polygons (rectangles) into QGIS (1.5.0).
I have installed the points2one plugin (0.2.4), but I cannot get it to take any input. "Input point layer" won't let me type in anything or select a file.
Also - if I get it working, what format do I need to have my polygon data in?
The data I want to map has four corners of a rectangle, and a single data variable that I'm tracking (number of facilities).
I want to create a custom tile layer for Google Maps. I'm planning on using: GMapCreator: http://www.casa.ucl.ac.uk/software/gmapcreator.asp Unless there is a plugin or better way of doing it with QGis?
Aaron
