[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
William Kyngesburye
woklist at kyngchaos.com
Tue Sep 28 13:54:26 PDT 2010
/usr/bin/python* should already exist, they are part of the system. That's not the problem.
The problem is that /usr/bin is NOT in the PATH in an OS X application. Applications have essentially no environment at all, but they do understand environment variables. Applications are in their own world, so to speak. There is a hidden mechanism for setting Application environment, but I don't want to spread that as it is cluncky to use (need 3rd party apps for a nice GUI front end), and is not well documented, if at all.
You got your symlinking idea backwards, but it does give me an idea for a workaround:
ln -s /usr/bin/python2.6 /Applications/Qgis.app/Contents/MacOS/bin/python
This puts a symlink to the system python in the Qgis application bin, which should be in the PATH in the Qgis environment.
On Sep 28, 2010, at 3:40 PM, Pierre Chevalier Géologue wrote:
> A stupid idea: why not doing a symbolic link to your python in your /usr/bin?
> At least, you can be sure that /usr/bin is in the path.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
