[Qgis-user] Does not accept int8
Ivan Mincik
ivan.mincik at gista.sk
Wed Sep 29 06:29:43 PDT 2010
On 09/29/2010 03:22 PM, Espen Isaksen wrote:
> Hi!
> We have a Postgis table with a primary key that is int8. QGIS will not
> open this table as it says it only accepts columns with int4.
> I get this error:
> "There were no columns in the table that were suitable as a qgis key
> into the table (either a column with a unique index and type int4 or a
> PostgreSQL oid column.
> The unique index on column 'sl_sdeid' is unsuitable because Quantum
> GIS does not currently support non-int4 type columns as a key into the
> table."
> Is there any way I can get QGIS to open this table with the int-8
> column? And without adding an extra int-4 column which I suppose might
> be a solution.
Hi, there was already discussion about it at developer mailing list and
there is already opened ticket:
https://trac.osgeo.org/qgis/ticket/62
Ivan Mincik, Gista s.r.o.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100929/ef144f74/attachment.html>
