[Qgis-user] Does not accept int8
Espen Isaksen
espen.isaksen at gmail.com
Thu Sep 30 01:27:59 PDT 2010
Ok, thanks for that information.
Espen
On Wed, Sep 29, 2010 at 3:29 PM, Ivan Mincik <ivan.mincik at gista.sk> wrote:
> On 09/29/2010 03:22 PM, Espen Isaksen wrote:
> Hi!
> We have a Postgis table with a primary key that is int8. QGIS will not
> open this table as it says it only accepts columns with int4.
> I get this error:
> "There were no columns in the table that were suitable as a qgis key
> into the table (either a column with a unique index and type int4 or a
> PostgreSQL oid column.
> The unique index on column 'sl_sdeid' is unsuitable because Quantum
> GIS does not currently support non-int4 type columns as a key into the
> table."
> Is there any way I can get QGIS to open this table with the int-8
> column? And without adding an extra int-4 column which I suppose might
> be a solution.
> Hi, there was already discussion about it at developer mailing list and
> there is already opened ticket:
> https://trac.osgeo.org/qgis/ticket/62
> Ivan Mincik, Gista s.r.o.
