[Qgis-user] newbie QGIS, pyQT and python question
karsten vennemann
karsten at terragis.net
Fri Apr 1 18:40:38 PDT 2011
I am working on my first QGIS plug-in wohoo .
But honestly this is my first ever stab at OO code in python using pyQT. I have <http://pastebin.com/dWT5eezP> http://pastebin.com/dWT5eezP (for code highlighting - or see end of message below trace back)
The line
self.inputConfig()
throws his error : argument 1 has unexpected type 'instance' .See traceback below. There I am trying to open a file selection dialogue window ....
Ay idea what it excepts instead of self ? Any python gurus ?
Thanks
Karsten
________________________________________________________________________________________________
File "D:/OSGeo4W/apps/qgis/./python/plugins\StreamEditCustomForm\streameditcustomform.py", line 72, in run
self.inputConfig()
File "D:/OSGeo4W/apps/qgis/./python/plugins\StreamEditCustomForm\streameditcustomform.py", line 54, in inputConfig
filename = QFileDialog.getOpenFileName(self, 'Open File', '.')
TypeError: QFileDialog.getOpenFileName(QWidget parent=None, QString caption=QString(), QString directory=QString(), QString filter=QString(), QString selectedFilter=None, QFileDialog.Options options=0): argument 1 has unexpected type 'instance'
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
# Import the PyQt and QGIS libraries
from PyQt4.QtCore import *
from PyQt4.QtGui import *
from qgis.core import *
# Initialize Qt resources from file resources.py
import resources
# Import the code for the dialog
from streameditcustomformdialog import StreamEditCustomFormDialog
class StreamEditCustomForm:
def __init__(self, iface):
# Save reference to the QGIS interface
self.iface = iface
def initGui(self):
# Create action that will start plugin configuration
self.action = QAction(QIcon(":/plugins/streameditcustomform/icon.png"), \
"Stream Edit Custom Form", self.iface.mainWindow())
# connect the action to the run method
QObject.connect(self.action, SIGNAL("triggered()"), self.run)
# Add toolbar button and menu item
self.iface.addToolBarIcon(self.action)
self.iface.addPluginToMenu("&Stream Edit Custom Form", self.action)
def unload(self):
# Remove the plugin menu item and icon
self.iface.removePluginMenu("&Stream Edit Custom Form",self.action)
self.iface.removeToolBarIcon(self.action)
def inputConfig(self):
fname = open(filename)
data = fname.read()
self.textEdit.setText(data)
fname.close()
# run method that performs all the real work
def run(self):
# create and show the dialog
dlg = StreamEditCustomFormDialog()
# show the dialog
dlg.show()
result = dlg.exec_()
# See if OK was pressed
if result == 1:
# do something useful (delete the line containing pass and
# substitute with your code
self.inputConfig()
pass
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110401/3ceea76a/attachment.html>
