[Qgis-user] newbie QGIS, pyQT and python question
Ricardo Filipe Soares Garcia da
ricardo.garcia.silva at gmail.com
Sat Apr 2 05:35:43 PDT 2011
Hi Karsten
I think these questions would be better suited for the qgis-developer
mailing-list.
Looking at pyqt's documentation[1], it seems the getOpenfileName
method's, first argument is the parent widget, and must be a QWidget
(or one of its subclasses) or None.
So you have some options:
1 - make this dialog a child of your main plugin window (which is not
present on the code snippet in your message).
2 - make this dialog a child of the main qgis window:
# code example
QgisMainWindow = qgis.utils.iface.mainWindow()
filename = QFileDialog.getOpenFileName(QgisMainWindow, 'Open File', '.')
3 - leave the 'parent' argument as None:
# code example
filename = QFileDialog.getOpenFileName(None, 'Open File', '.')
I think either option should work. Good luck with your plugin ;)
[1] - http://www.riverbankcomputing.co.uk/static/Docs/PyQt4/html/qfiledialog.html
On Sat, Apr 2, 2011 at 2:40 AM, karsten vennemann <karsten at terragis.net> wrote:
> Hi,
> I am working on my first QGIS plug-in wohoo .
> But honestly this is my first ever stab at OO code in python using pyQT. I have http://pastebin.com/dWT5eezP (for code highlighting - or see end of message below trace back)
> The line
> self.inputConfig()
> throws his error : argument 1 has unexpected type 'instance' .See traceback below. There I am trying to open a file selection dialogue window ....
> Ay idea what it excepts instead of self ? Any python gurus ?
> Thanks
> Karsten
> ________________________________________________________________________________________________
> Traceback (most recent call last):
> File "D:/OSGeo4W/apps/qgis/./python/plugins\StreamEditCustomForm\streameditcustomform.py", line 72, in run
> self.inputConfig()
> File "D:/OSGeo4W/apps/qgis/./python/plugins\StreamEditCustomForm\streameditcustomform.py", line 54, in inputConfig
> filename = QFileDialog.getOpenFileName(self, 'Open File', '.')
> TypeError: QFileDialog.getOpenFileName(QWidget parent=None, QString caption=QString(), QString directory=QString(), QString filter=QString(), QString selectedFilter=None, QFileDialog.Options options=0): argument 1 has unexpected type 'instance'
> Python version:
> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> # Import the PyQt and QGIS libraries
> from PyQt4.QtCore import *
> from PyQt4.QtGui import *
> from qgis.core import *
> # Initialize Qt resources from file resources.py
> import resources
> # Import the code for the dialog
> from streameditcustomformdialog import StreamEditCustomFormDialog
> class StreamEditCustomForm:
> def __init__(self, iface):
> # Save reference to the QGIS interface
> self.iface = iface
> def initGui(self):
> # Create action that will start plugin configuration
> self.action = QAction(QIcon(":/plugins/streameditcustomform/icon.png"), \
> "Stream Edit Custom Form", self.iface.mainWindow())
> # connect the action to the run method
> QObject.connect(self.action, SIGNAL("triggered()"), self.run)
> # Add toolbar button and menu item
> self.iface.addToolBarIcon(self.action)
> self.iface.addPluginToMenu("&Stream Edit Custom Form", self.action)
> def unload(self):
> # Remove the plugin menu item and icon
> self.iface.removePluginMenu("&Stream Edit Custom Form",self.action)
> self.iface.removeToolBarIcon(self.action)
> def inputConfig(self):
> fname = open(filename)
> data = fname.read()
> self.textEdit.setText(data)
> fname.close()
> # run method that performs all the real work
> def run(self):
> # create and show the dialog
> dlg = StreamEditCustomFormDialog()
> # show the dialog
> dlg.show()
> result = dlg.exec_()
> # See if OK was pressed
> if result == 1:
> # do something useful (delete the line containing pass and
> # substitute with your code
> self.inputConfig()
> pass
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
