[Qgis-user] Understanding the rule-based renderer
Sam Vekemans
acrosscanadatrails at gmail.com
Fri Apr 8 07:32:03 PDT 2011
Ok,
I ask as i am making my own set of rules/standards for the CommonMap
API (which works the same as OpenStreetMap) accept the licence of the
data is ccBY, instead of ccBYsa/Odbl.
So the source datasets begin with Natural Earth, GeoBase (Canada),
CanVec (Canada), TIGER (USA), LINZ (New Zealand) etc. and building a
set of standards, which are 'inspired' by mapnik/cyclemap.
Are their any 'favorate' well known datasets which have a good set of
features that you (qgis Community) would like to see incorporated into
the CommonMap Features rendering schema?
thanks,
Sam
On 4/8/11, Andreas Neumann <a.neumann at carto.net> wrote:
> It would make sense for very well-known datasets with a fixed
> structure. Potential candidates are national survey datasets that are
> widely used or OpenStreetMap data.
> In my case, the rendering rules are very specific to my own data
> structure. It wouldn't make sense to share them.
> Andreas
> On Fri, 8 Apr 2011 05:37:52 -0700, Sam Vekemans wrote:
>> Hi,
>> Is their a list somewhere which shows all of the rendering rules
>> which
>> people are using (the beginings of a standards system)?
>> Thanks,
>> Sam
>> On 4/8/11, Martin Dobias <wonder.sk at gmail.com> wrote:
>>> On Fri, Apr 8, 2011 at 11:36 AM, Andreas Neumann
>>> wrote:
>>>> Hi,
>>>> I am trying to better understand the rule based renderer.
>>>> Which version is correct?
>>>> a) QGIS is rendering all features of the first rule, then the
>>>> second rule,
>>>> etc, Features of the first rule are rendered first, features of the
>>>> second
>>>> rule on top of features from the first rule
>>>> b) QGIS is rendering each feature on by one and decides which rule
>>>> applies.
>>>> I hope it is not version b), I hoped it behaves like version a) but
>>>> it
>>>> behaves a bit odd with my data. For my data it seems like the order
>>>> of the
>>>> rule has no influence on the rendering order ;-(
>>> Hi Andreas
>>> the rule based renderer uses the b) option: it goes through the
>>> features one by one and applies all matching rules (in the order in
>>> which they appear). Mayeul Kaufmann has done some work in order to
>>> support option a) by implementing support for symbol levels so that
>>> the rendering order can be overridden.
>>> My ultimate goal is to only support the option a) in a way how SLD
>>> specifies it: rules are grouped and these groups are rendered one
>>> after each other.
>>> Regards
>>> Martin
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
Across Canada Trails - Beyond 2017 - The National Trails Network
Victoria, BC Canada
Twitter: @Acrosscanada
Blog: http://acrosscanadatrails.posterous.com/
Facebook: http://www.facebook.com/sam.vekemans
Skype: 'Sam Vekemans'
Member, CommonMap Inc. http://commonmap.org/
IRC: irc://irc.oftc.net #CommonMap
Also find us on Facebook, Twitter and LinkedIn
