[Qgis-user] Understanding the rule-based renderer
    Mike
    mswope at gmail.com
    Fri Apr  8 11:04:14 PDT 2011
It sounds like that the USGS DLG might be better suited than Tiger, though
it is outdated. The DLG is a more similar product type to the LINZ topo and
Canvec stuff.
DLG is being replaced by the nationalmap.gov stuff - see products and
services on left side, as well as ustopo (which uses data from the products
and services area).
DLG found here http://edc2.usgs.gov/geodata/index.php
On Fri, Apr 8, 2011 at 8:32 AM, Sam Vekemans
<acrosscanadatrails at gmail.com>wrote:
> Ok,
> I ask as i am making my own set of rules/standards for the CommonMap
> API (which works the same as OpenStreetMap) accept the licence of the
> data is ccBY, instead of ccBYsa/Odbl.
> So the source datasets begin with Natural Earth, GeoBase (Canada),
> CanVec (Canada), TIGER (USA), LINZ (New Zealand) etc.  and building a
> set of standards, which are 'inspired' by mapnik/cyclemap.
> Are their any 'favorate' well known datasets which have a good set of
> features that you (qgis Community) would like to see incorporated into
> the CommonMap Features rendering schema?
> thanks,
> Sam
> On 4/8/11, Andreas Neumann <a.neumann at carto.net> wrote:
> >  It would make sense for very well-known datasets with a fixed
> >  structure. Potential candidates are national survey datasets that are
> >  widely used or OpenStreetMap data.
> >  In my case, the rendering rules are very specific to my own data
> >  structure. It wouldn't make sense to share them.
> >  Andreas
> >  On Fri, 8 Apr 2011 05:37:52 -0700, Sam Vekemans wrote:
> >> Hi,
> >> Is their a list somewhere which shows all of the rendering rules
> >> which
> >> people are using (the beginings of a standards system)?
> >> Thanks,
> >> Sam
> >> On 4/8/11, Martin Dobias <wonder.sk at gmail.com> wrote:
> >>> On Fri, Apr 8, 2011 at 11:36 AM, Andreas Neumann
> >>> wrote:
> >>>> Hi,
> >>>> I am trying to better understand the rule based renderer.
> >>>> Which version is correct?
> >>>> a) QGIS is rendering all features of the first rule, then the
> >>>> second rule,
> >>>> etc, Features of the first rule are rendered first, features of the
> >>>> second
> >>>> rule on top of features from the first rule
> >>>> b) QGIS is rendering each feature on by one and decides which rule
> >>>> applies.
> >>>> I hope it is not version b), I hoped it behaves like version a) but
> >>>> it
> >>>> behaves a bit odd with my data. For my data it seems like the order
> >>>> of the
> >>>> rule has no influence on the rendering order ;-(
> >>> Hi Andreas
> >>> the rule based renderer uses the b) option: it goes through the
> >>> features one by one and applies all matching rules (in the order in
> >>> which they appear). Mayeul Kaufmann has done some work in order to
> >>> support option a) by implementing support for symbol levels so that
> >>> the rendering order can be overridden.
> >>> My ultimate goal is to only support the option a) in a way how SLD
> >>> specifies it: rules are grouped and these groups are rendered one
> >>> after each other.
> >>> Regards
> >>> Martin
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >  Andreas Neumann
> >  Böschacherstrasse 10A
> >  8624 Grüt (Gossau ZH)
> >  Switzerland
> Across Canada Trails - Beyond 2017 - The National Trails Network
> Victoria, BC Canada
> Twitter: @Acrosscanada
> Blog: http://acrosscanadatrails.posterous.com/
> Facebook: http://www.facebook.com/sam.vekemans
> Skype: 'Sam Vekemans'
> Member, CommonMap Inc.  http://commonmap.org/
> IRC: irc://irc.oftc.net #CommonMap
> Also find us on Facebook, Twitter and LinkedIn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110408/9d3bc965/attachment.html>
