[Qgis-user] qgis-mapserver on Windows ignore my postgis and shapefile layers
Oliver Christen oliver.christen at camptocamp.com
Fri Apr 29 05:08:07 PDT 2011
sadely no
I gave up, as it was mostly for testing only and I had no more time to spend
on this problem.
the setup is mostly the same between linux and windows but for the fact you
must use cgi and not fastcgi as indicated in
http://karlinapp.ethz.ch/qgis_wms/configuration/index.html
also here is my apache conf, though it may NOT be ok
<Directory "C:/prog/web/wamp/apache2/cgi-bin">
    AllowOverride None
    Options +ExecCGI
    Order allow,deny
    Allow from all
    SetEnv LD_LIBRARY_PATH "C:/prog/dev/gis/Quantum GIS
1.6/apps/qgis/plugins"
</Directory>
regards
Oliver Christen
Camptocamp SA
PSE-A, Parc Scientifique EPFL
1015 Lausanne, Switzerland
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
www.camptocamp.com
----- Original Message -----
From: "Giovanni Manghi" <giovanni.manghi at gmail.com>
To: "Oliver Christen" <oliver.christen at camptocamp.com>
Cc: <qgis-user at lists.osgeo.org>; "Nelson" <nelsonjsilva at simplesnet.pt>;
<portugal at lists.osgeo.org>
Sent: Friday, April 29, 2011 9:59 AM
Subject: Re: [Qgis-user] qgis-mapserver on Windows ignore my postgis and
shapefile layers
> Hi,
>> Im having some teoubles with qgis-mapserver on Windows.
> Did you managed to solve this problems in qgis-mapaserver under Windows?
> By the way, there is some guide about installing/making it work under
> Windows?
> Thanks in advance
> -- Giovanni --
