[Qgis-user] qgis-mapserver on Windows ignore my postgis and shapefile layers
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Apr 29 05:29:26 PDT 2011
Hi Oliver
> the setup is mostly the same between linux and windows but for the fact you
> must use cgi and not fastcgi as indicated in
> http://karlinapp.ethz.ch/qgis_wms/configuration/index.html
This webpage is a pretty old one. There is no reason why it should not work on
windows with fastcgi. I however don't have experience with it on win.
Regards,
Marco
Am Freitag, 29. April 2011, um 14.08:07 schrieb Oliver Christen:
> sadely no
> I gave up, as it was mostly for testing only and I had no more time to
> spend on this problem.
> also here is my apache conf, though it may NOT be ok
> <Directory "C:/prog/web/wamp/apache2/cgi-bin">
> AllowOverride None
> Options +ExecCGI
> Order allow,deny
> Allow from all
> SetEnv LD_LIBRARY_PATH "C:/prog/dev/gis/Quantum GIS
> 1.6/apps/qgis/plugins"
> </Directory>
> regards
> Oliver Christen
> Camptocamp SA
> PSE-A, Parc Scientifique EPFL
> 1015 Lausanne, Switzerland
> +41 21 619 10 23 (direct)
> +41 21 619 10 10 (centrale)
> oliver.christen at camptocamp.com
> www.camptocamp.com
> ----- Original Message -----
> From: "Giovanni Manghi" <giovanni.manghi at gmail.com>
> To: "Oliver Christen" <oliver.christen at camptocamp.com>
> Cc: <qgis-user at lists.osgeo.org>; "Nelson" <nelsonjsilva at simplesnet.pt>;
> <portugal at lists.osgeo.org>
> Sent: Friday, April 29, 2011 9:59 AM
> Subject: Re: [Qgis-user] qgis-mapserver on Windows ignore my postgis and
> shapefile layers
> > Hi,
> >> Im having some teoubles with qgis-mapserver on Windows.
> > Did you managed to solve this problems in qgis-mapaserver under Windows?
> > By the way, there is some guide about installing/making it work under
> > Windows?
> > Thanks in advance
> > -- Giovanni --
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
