[Qgis-user] Tif too slow to show
Kris Nackaerts
knackaerts at gmx.net
Fri Apr 29 05:57:16 PDT 2011
I see now that your files are CCITTFAX4 compressed.
I had similar B&W rasters, topographic maps from Belgium, same compression.
I uncompressed all, should boost performance. Plus, I added plenty overviews.
Kris
-------- Original-Nachricht --------
> Datum: Fri, 29 Apr 2011 14:40:29 +0200
> Von: Patrice Vetsel <ubuntu at kagou.fr>
> An: Kris Nackaerts <knackaerts at gmx.net>
> Betreff: Re: [Qgis-user] Tif too slow to show
> I'v done a
> gdaladdo -r average 3004221146000AB010200001.tif 2 4 8 16
> but QGis is always too slow.
> Thanks
> Le 29 avr. 2011 à 14:21, Kris Nackaerts a écrit :
> > Dear,
> > I would start trying gdaladdo to create overviews. Does wonders for
> speed.
> > I'm working right now with a global Landsat dataset, vrt, +4000 tiles,
> roughly 700k by 300k pixels in total, and even this can be handled
> efficiently once you've overviews.
> > I mainly use uncompressed geotiffs.
> > Kris
> >> Datum: Fri, 29 Apr 2011 14:08:00 +0200
> >> An: qgis-user at lists.osgeo.org
> >> Betreff: [Qgis-user] Tif too slow to show
> >> Hi,
> >> with an original raster (tif+tfw), from french cadastre, when I open it
> >> under qgis, it's unusable because QGis is horribly slow.
> >> with the same raster, but after using georef extension (tif+aux.xml),
> QGis
> >> is responsive
> >> here I put gdalinfo of the original (slow) and referenced :
> >> What's the problem with the first ? I would prefer to not have to
> manually
> >> georeference all my original rasters ;)
> >> In the same time, what's the most efficient raster type to use with
> QGis ?
> >> Regards
> >> Patrice Vetsel
> >> SLOW :
> >> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$
> >> /Library/Frameworks/GDAL.framework/Programs/gdalinfo
> ~/Desktop/3004221146000AB010200001.tif
> >> Driver: GTiff/GeoTIFF
> >> Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
> >> /Users/Patrice/Desktop/3004221146000AB010200001.tfw
> >> Size is 12329, 8760
> >> Coordinate System is `'
> >> GeoTransform =
> >> 740551.2494, 0.078, 0.1506
> >> 189669.7013, 0.1506, -0.078
> >> Metadata:
> >> TIFFTAG_ARTIST=JBG-PYV-APIC
> >> TIFFTAG_XRESOLUTION=300
> >> TIFFTAG_YRESOLUTION=300
> >> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> >> Image Structure Metadata:
> >> COMPRESSION=CCITTFAX4
> >> INTERLEAVE=BAND
> >> MINISWHITE=YES
> >> Corner Coordinates:
> >> Upper Left ( 740551.249, 189669.701)
> >> Lower Left ( 741870.505, 188986.421)
> >> Upper Right ( 741512.911, 191526.449)
> >> Lower Right ( 742832.167, 190843.169)
> >> Center ( 741691.708, 190256.435)
> >> Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
> >> NBITS=1
> >> Color Table (RGB with 2 entries)
> >> 0: 255,255,255,255
> >> 1: 0,0,0,255
> >> OK :
> ~/Desktop/testgeo/AB_georef.tif
> >> Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
> >> /Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
> >> Size is 13446, 14968
> >> Origin = (740550.783870017039590,191526.220101331215119)
> >> Pixel Size = (0.169699598291267,-0.169699598291267)
> >> INTERLEAVE=BAND
> >> Corner Coordinates:
> >> Upper Left ( 740550.784, 191526.220)
> >> Lower Left ( 740550.784, 188986.157)
> >> Upper Right ( 742832.565, 191526.220)
> >> Lower Right ( 742832.565, 188986.157)
> >> Center ( 741691.674, 190256.188)
> >> Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
> >> Color Table (RGB with 256 entries)
> >> 0: 255,255,255,255
> >> 1: 0,0,0,255
> >> 2: 0,0,0,255
> >> 3: 0,0,0,255
> >> 4: 0,0,0,255
> >> 5: 0,0,0,255
> >> 6: 0,0,0,255
> >> 7: 0,0,0,255
> >> 8: 0,0,0,255
> >> 9: 0,0,0,255
> >> 10: 0,0,0,255
> >> 11: 0,0,0,255
> >> 12: 0,0,0,255
> >> 13: 0,0,0,255
> >> 14: 0,0,0,255
> >> 15: 0,0,0,255
> >> 16: 0,0,0,255
> >> 17: 0,0,0,255
> >> 18: 0,0,0,255
> >> 19: 0,0,0,255
> >> 20: 0,0,0,255
> >> 21: 0,0,0,255
> >> 22: 0,0,0,255
> >> 23: 0,0,0,255
> >> 24: 0,0,0,255
> >> 25: 0,0,0,255
> >> 26: 0,0,0,255
> >> 27: 0,0,0,255
> >> 28: 0,0,0,255
> >> 29: 0,0,0,255
> >> 30: 0,0,0,255
> >> 31: 0,0,0,255
> >> 32: 0,0,0,255
> >> 33: 0,0,0,255
> >> 34: 0,0,0,255
> >> 35: 0,0,0,255
> >> 36: 0,0,0,255
> >> 37: 0,0,0,255
> >> 38: 0,0,0,255
> >> 39: 0,0,0,255
> >> 40: 0,0,0,255
> >> 41: 0,0,0,255
> >> 42: 0,0,0,255
> >> 43: 0,0,0,255
> >> 44: 0,0,0,255
> >> 45: 0,0,0,255
> >> 46: 0,0,0,255
> >> 47: 0,0,0,255
> >> 48: 0,0,0,255
> >> 49: 0,0,0,255
> >> 50: 0,0,0,255
> >> 51: 0,0,0,255
> >> 52: 0,0,0,255
> >> 53: 0,0,0,255
> >> 54: 0,0,0,255
> >> 55: 0,0,0,255
> >> 56: 0,0,0,255
> >> 57: 0,0,0,255
> >> 58: 0,0,0,255
> >> 59: 0,0,0,255
> >> 60: 0,0,0,255
> >> 61: 0,0,0,255
> >> 62: 0,0,0,255
> >> 63: 0,0,0,255
> >> 64: 0,0,0,255
> >> 65: 0,0,0,255
> >> 66: 0,0,0,255
> >> 67: 0,0,0,255
> >> 68: 0,0,0,255
> >> 69: 0,0,0,255
> >> 70: 0,0,0,255
> >> 71: 0,0,0,255
> >> 72: 0,0,0,255
> >> 73: 0,0,0,255
> >> 74: 0,0,0,255
> >> 75: 0,0,0,255
> >> 76: 0,0,0,255
> >> 77: 0,0,0,255
> >> 78: 0,0,0,255
> >> 79: 0,0,0,255
> >> 80: 0,0,0,255
> >> 81: 0,0,0,255
> >> 82: 0,0,0,255
> >> 83: 0,0,0,255
> >> 84: 0,0,0,255
> >> 85: 0,0,0,255
> >> 86: 0,0,0,255
> >> 87: 0,0,0,255
> >> 88: 0,0,0,255
> >> 89: 0,0,0,255
> >> 90: 0,0,0,255
> >> 91: 0,0,0,255
> >> 92: 0,0,0,255
> >> 93: 0,0,0,255
> >> 94: 0,0,0,255
> >> 95: 0,0,0,255
> >> 96: 0,0,0,255
> >> 97: 0,0,0,255
> >> 98: 0,0,0,255
> >> 99: 0,0,0,255
> >> 100: 0,0,0,255
> >> 101: 0,0,0,255
> >> 102: 0,0,0,255
> >> 103: 0,0,0,255
> >> 104: 0,0,0,255
> >> 105: 0,0,0,255
> >> 106: 0,0,0,255
> >> 107: 0,0,0,255
> >> 108: 0,0,0,255
> >> 109: 0,0,0,255
> >> 110: 0,0,0,255
> >> 111: 0,0,0,255
> >> 112: 0,0,0,255
> >> 113: 0,0,0,255
> >> 114: 0,0,0,255
> >> 115: 0,0,0,255
> >> 116: 0,0,0,255
> >> 117: 0,0,0,255
> >> 118: 0,0,0,255
> >> 119: 0,0,0,255
> >> 120: 0,0,0,255
> >> 121: 0,0,0,255
> >> 122: 0,0,0,255
> >> 123: 0,0,0,255
> >> 124: 0,0,0,255
> >> 125: 0,0,0,255
> >> 126: 0,0,0,255
> >> 127: 0,0,0,255
> >> 128: 0,0,0,255
> >> 129: 0,0,0,255
> >> 130: 0,0,0,255
> >> 131: 0,0,0,255
> >> 132: 0,0,0,255
> >> 133: 0,0,0,255
> >> 134: 0,0,0,255
> >> 135: 0,0,0,255
> >> 136: 0,0,0,255
> >> 137: 0,0,0,255
> >> 138: 0,0,0,255
> >> 139: 0,0,0,255
> >> 140: 0,0,0,255
> >> 141: 0,0,0,255
> >> 142: 0,0,0,255
> >> 143: 0,0,0,255
> >> 144: 0,0,0,255
> >> 145: 0,0,0,255
> >> 146: 0,0,0,255
> >> 147: 0,0,0,255
> >> 148: 0,0,0,255
> >> 149: 0,0,0,255
> >> 150: 0,0,0,255
> >> 151: 0,0,0,255
> >> 152: 0,0,0,255
> >> 153: 0,0,0,255
> >> 154: 0,0,0,255
> >> 155: 0,0,0,255
> >> 156: 0,0,0,255
> >> 157: 0,0,0,255
> >> 158: 0,0,0,255
> >> 159: 0,0,0,255
> >> 160: 0,0,0,255
> >> 161: 0,0,0,255
> >> 162: 0,0,0,255
> >> 163: 0,0,0,255
> >> 164: 0,0,0,255
> >> 165: 0,0,0,255
> >> 166: 0,0,0,255
> >> 167: 0,0,0,255
> >> 168: 0,0,0,255
> >> 169: 0,0,0,255
> >> 170: 0,0,0,255
> >> 171: 0,0,0,255
> >> 172: 0,0,0,255
> >> 173: 0,0,0,255
> >> 174: 0,0,0,255
> >> 175: 0,0,0,255
> >> 176: 0,0,0,255
> >> 177: 0,0,0,255
> >> 178: 0,0,0,255
> >> 179: 0,0,0,255
> >> 180: 0,0,0,255
> >> 181: 0,0,0,255
> >> 182: 0,0,0,255
> >> 183: 0,0,0,255
> >> 184: 0,0,0,255
> >> 185: 0,0,0,255
> >> 186: 0,0,0,255
> >> 187: 0,0,0,255
> >> 188: 0,0,0,255
> >> 189: 0,0,0,255
> >> 190: 0,0,0,255
> >> 191: 0,0,0,255
> >> 192: 0,0,0,255
> >> 193: 0,0,0,255
> >> 194: 0,0,0,255
> >> 195: 0,0,0,255
> >> 196: 0,0,0,255
> >> 197: 0,0,0,255
> >> 198: 0,0,0,255
> >> 199: 0,0,0,255
> >> 200: 0,0,0,255
> >> 201: 0,0,0,255
> >> 202: 0,0,0,255
> >> 203: 0,0,0,255
> >> 204: 0,0,0,255
> >> 205: 0,0,0,255
> >> 206: 0,0,0,255
> >> 207: 0,0,0,255
> >> 208: 0,0,0,255
> >> 209: 0,0,0,255
> >> 210: 0,0,0,255
> >> 211: 0,0,0,255
> >> 212: 0,0,0,255
> >> 213: 0,0,0,255
> >> 214: 0,0,0,255
> >> 215: 0,0,0,255
> >> 216: 0,0,0,255
> >> 217: 0,0,0,255
> >> 218: 0,0,0,255
> >> 219: 0,0,0,255
> >> 220: 0,0,0,255
> >> 221: 0,0,0,255
> >> 222: 0,0,0,255
> >> 223: 0,0,0,255
> >> 224: 0,0,0,255
> >> 225: 0,0,0,255
> >> 226: 0,0,0,255
> >> 227: 0,0,0,255
> >> 228: 0,0,0,255
> >> 229: 0,0,0,255
> >> 230: 0,0,0,255
> >> 231: 0,0,0,255
> >> 232: 0,0,0,255
> >> 233: 0,0,0,255
> >> 234: 0,0,0,255
> >> 235: 0,0,0,255
> >> 236: 0,0,0,255
> >> 237: 0,0,0,255
> >> 238: 0,0,0,255
> >> 239: 0,0,0,255
> >> 240: 0,0,0,255
> >> 241: 0,0,0,255
> >> 242: 0,0,0,255
> >> 243: 0,0,0,255
> >> 244: 0,0,0,255
> >> 245: 0,0,0,255
> >> 246: 0,0,0,255
> >> 247: 0,0,0,255
> >> 248: 0,0,0,255
> >> 249: 0,0,0,255
> >> 250: 0,0,0,255
> >> 251: 0,0,0,255
> >> 252: 0,0,0,255
> >> 253: 0,0,0,255
> >> 254: 0,0,0,255
> >> 255: 0,0,0,255
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
> > belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
