[Qgis-user] Tif too slow to show
Luca Lanteri
mescal72 at gmail.com
Fri Apr 29 06:21:55 PDT 2011
I've had the same problem with my ortophoto. I'm not really sure but I think
the problem is due to the rotation parameter that is not managed at the best
by QGIS. Some months ago I've tried to oped a ticket (
https://trac.osgeo.org/qgis/ticket/3460).
2011/4/29 Kris Nackaerts <knackaerts at gmx.net>
> I see now that your files are CCITTFAX4 compressed.
> I had similar B&W rasters, topographic maps from Belgium, same compression.
> I uncompressed all, should boost performance. Plus, I added plenty
> overviews.
> Kris
> -------- Original-Nachricht --------
> > Datum: Fri, 29 Apr 2011 14:40:29 +0200
> > Von: Patrice Vetsel <ubuntu at kagou.fr>
> > An: Kris Nackaerts <knackaerts at gmx.net>
> > Betreff: Re: [Qgis-user] Tif too slow to show
> > I'v done a
> > gdaladdo -r average 3004221146000AB010200001.tif 2 4 8 16
> > but QGis is always too slow.
> > Thanks
> > Le 29 avr. 2011 à 14:21, Kris Nackaerts a écrit :
> > > Dear,
> > > I would start trying gdaladdo to create overviews. Does wonders for
> > speed.
> > > I'm working right now with a global Landsat dataset, vrt, +4000 tiles,
> > roughly 700k by 300k pixels in total, and even this can be handled
> > efficiently once you've overviews.
> > > I mainly use uncompressed geotiffs.
> > > Kris
> > >> Datum: Fri, 29 Apr 2011 14:08:00 +0200
> > >> An: qgis-user at lists.osgeo.org
> > >> Betreff: [Qgis-user] Tif too slow to show
> > >> Hi,
> > >> with an original raster (tif+tfw), from french cadastre, when I open
> it
> > >> under qgis, it's unusable because QGis is horribly slow.
> > >> with the same raster, but after using georef extension (tif+aux.xml),
> > QGis
> > >> is responsive
> > >> here I put gdalinfo of the original (slow) and referenced :
> > >> What's the problem with the first ? I would prefer to not have to
> > manually
> > >> georeference all my original rasters ;)
> > >> In the same time, what's the most efficient raster type to use with
> > QGis ?
> > >> Regards
> > >> Patrice Vetsel
> > >> SLOW :
> > >> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$
> > >> /Library/Frameworks/GDAL.framework/Programs/gdalinfo
> > ~/Desktop/3004221146000AB010200001.tif
> > >> Driver: GTiff/GeoTIFF
> > >> Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
> > >> /Users/Patrice/Desktop/3004221146000AB010200001.tfw
> > >> Size is 12329, 8760
> > >> Coordinate System is `'
> > >> GeoTransform =
> > >> 740551.2494, 0.078, 0.1506
> > >> 189669.7013, 0.1506, -0.078
> > >> Metadata:
> > >> TIFFTAG_ARTIST=JBG-PYV-APIC
> > >> TIFFTAG_XRESOLUTION=300
> > >> TIFFTAG_YRESOLUTION=300
> > >> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> > >> Image Structure Metadata:
> > >> COMPRESSION=CCITTFAX4
> > >> INTERLEAVE=BAND
> > >> MINISWHITE=YES
> > >> Corner Coordinates:
> > >> Upper Left ( 740551.249, 189669.701)
> > >> Lower Left ( 741870.505, 188986.421)
> > >> Upper Right ( 741512.911, 191526.449)
> > >> Lower Right ( 742832.167, 190843.169)
> > >> Center ( 741691.708, 190256.435)
> > >> Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
> > >> NBITS=1
> > >> Color Table (RGB with 2 entries)
> > >> 0: 255,255,255,255
> > >> 1: 0,0,0,255
> > >> OK :
> > ~/Desktop/testgeo/AB_georef.tif
> > >> Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
> > >> /Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
> > >> Size is 13446, 14968
> > >> Origin = (740550.783870017039590,191526.220101331215119)
> > >> Pixel Size = (0.169699598291267,-0.169699598291267)
> > >> INTERLEAVE=BAND
> > >> Corner Coordinates:
> > >> Upper Left ( 740550.784, 191526.220)
> > >> Lower Left ( 740550.784, 188986.157)
> > >> Upper Right ( 742832.565, 191526.220)
> > >> Lower Right ( 742832.565, 188986.157)
> > >> Center ( 741691.674, 190256.188)
> > >> Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
> > >> Color Table (RGB with 256 entries)
> > >> 0: 255,255,255,255
> > >> 1: 0,0,0,255
> > >> 2: 0,0,0,255
> > >> 3: 0,0,0,255
> > >> 4: 0,0,0,255
> > >> 5: 0,0,0,255
> > >> 6: 0,0,0,255
> > >> 7: 0,0,0,255
> > >> 8: 0,0,0,255
> > >> 9: 0,0,0,255
> > >> 10: 0,0,0,255
> > >> 11: 0,0,0,255
> > >> 12: 0,0,0,255
> > >> 13: 0,0,0,255
> > >> 14: 0,0,0,255
> > >> 15: 0,0,0,255
> > >> 16: 0,0,0,255
> > >> 17: 0,0,0,255
> > >> 18: 0,0,0,255
> > >> 19: 0,0,0,255
> > >> 20: 0,0,0,255
> > >> 21: 0,0,0,255
> > >> 22: 0,0,0,255
> > >> 23: 0,0,0,255
> > >> 24: 0,0,0,255
> > >> 25: 0,0,0,255
> > >> 26: 0,0,0,255
> > >> 27: 0,0,0,255
> > >> 28: 0,0,0,255
> > >> 29: 0,0,0,255
> > >> 30: 0,0,0,255
> > >> 31: 0,0,0,255
> > >> 32: 0,0,0,255
> > >> 33: 0,0,0,255
> > >> 34: 0,0,0,255
> > >> 35: 0,0,0,255
> > >> 36: 0,0,0,255
> > >> 37: 0,0,0,255
> > >> 38: 0,0,0,255
> > >> 39: 0,0,0,255
> > >> 40: 0,0,0,255
> > >> 41: 0,0,0,255
> > >> 42: 0,0,0,255
> > >> 43: 0,0,0,255
> > >> 44: 0,0,0,255
> > >> 45: 0,0,0,255
> > >> 46: 0,0,0,255
> > >> 47: 0,0,0,255
> > >> 48: 0,0,0,255
> > >> 49: 0,0,0,255
> > >> 50: 0,0,0,255
> > >> 51: 0,0,0,255
> > >> 52: 0,0,0,255
> > >> 53: 0,0,0,255
> > >> 54: 0,0,0,255
> > >> 55: 0,0,0,255
> > >> 56: 0,0,0,255
> > >> 57: 0,0,0,255
> > >> 58: 0,0,0,255
> > >> 59: 0,0,0,255
> > >> 60: 0,0,0,255
> > >> 61: 0,0,0,255
> > >> 62: 0,0,0,255
> > >> 63: 0,0,0,255
> > >> 64: 0,0,0,255
> > >> 65: 0,0,0,255
> > >> 66: 0,0,0,255
> > >> 67: 0,0,0,255
> > >> 68: 0,0,0,255
> > >> 69: 0,0,0,255
> > >> 70: 0,0,0,255
> > >> 71: 0,0,0,255
> > >> 72: 0,0,0,255
> > >> 73: 0,0,0,255
> > >> 74: 0,0,0,255
> > >> 75: 0,0,0,255
> > >> 76: 0,0,0,255
> > >> 77: 0,0,0,255
> > >> 78: 0,0,0,255
> > >> 79: 0,0,0,255
> > >> 80: 0,0,0,255
> > >> 81: 0,0,0,255
> > >> 82: 0,0,0,255
> > >> 83: 0,0,0,255
> > >> 84: 0,0,0,255
> > >> 85: 0,0,0,255
> > >> 86: 0,0,0,255
> > >> 87: 0,0,0,255
> > >> 88: 0,0,0,255
> > >> 89: 0,0,0,255
> > >> 90: 0,0,0,255
> > >> 91: 0,0,0,255
> > >> 92: 0,0,0,255
> > >> 93: 0,0,0,255
> > >> 94: 0,0,0,255
> > >> 95: 0,0,0,255
> > >> 96: 0,0,0,255
> > >> 97: 0,0,0,255
> > >> 98: 0,0,0,255
> > >> 99: 0,0,0,255
> > >> 100: 0,0,0,255
> > >> 101: 0,0,0,255
> > >> 102: 0,0,0,255
> > >> 103: 0,0,0,255
> > >> 104: 0,0,0,255
> > >> 105: 0,0,0,255
> > >> 106: 0,0,0,255
> > >> 107: 0,0,0,255
> > >> 108: 0,0,0,255
> > >> 109: 0,0,0,255
> > >> 110: 0,0,0,255
> > >> 111: 0,0,0,255
> > >> 112: 0,0,0,255
> > >> 113: 0,0,0,255
> > >> 114: 0,0,0,255
> > >> 115: 0,0,0,255
> > >> 116: 0,0,0,255
> > >> 117: 0,0,0,255
> > >> 118: 0,0,0,255
> > >> 119: 0,0,0,255
> > >> 120: 0,0,0,255
> > >> 121: 0,0,0,255
> > >> 122: 0,0,0,255
> > >> 123: 0,0,0,255
> > >> 124: 0,0,0,255
> > >> 125: 0,0,0,255
> > >> 126: 0,0,0,255
> > >> 127: 0,0,0,255
> > >> 128: 0,0,0,255
> > >> 129: 0,0,0,255
> > >> 130: 0,0,0,255
> > >> 131: 0,0,0,255
> > >> 132: 0,0,0,255
> > >> 133: 0,0,0,255
> > >> 134: 0,0,0,255
> > >> 135: 0,0,0,255
> > >> 136: 0,0,0,255
> > >> 137: 0,0,0,255
> > >> 138: 0,0,0,255
> > >> 139: 0,0,0,255
> > >> 140: 0,0,0,255
> > >> 141: 0,0,0,255
> > >> 142: 0,0,0,255
> > >> 143: 0,0,0,255
> > >> 144: 0,0,0,255
> > >> 145: 0,0,0,255
> > >> 146: 0,0,0,255
> > >> 147: 0,0,0,255
> > >> 148: 0,0,0,255
> > >> 149: 0,0,0,255
> > >> 150: 0,0,0,255
> > >> 151: 0,0,0,255
> > >> 152: 0,0,0,255
> > >> 153: 0,0,0,255
> > >> 154: 0,0,0,255
> > >> 155: 0,0,0,255
> > >> 156: 0,0,0,255
> > >> 157: 0,0,0,255
> > >> 158: 0,0,0,255
> > >> 159: 0,0,0,255
> > >> 160: 0,0,0,255
> > >> 161: 0,0,0,255
> > >> 162: 0,0,0,255
> > >> 163: 0,0,0,255
> > >> 164: 0,0,0,255
> > >> 165: 0,0,0,255
> > >> 166: 0,0,0,255
> > >> 167: 0,0,0,255
> > >> 168: 0,0,0,255
> > >> 169: 0,0,0,255
> > >> 170: 0,0,0,255
> > >> 171: 0,0,0,255
> > >> 172: 0,0,0,255
> > >> 173: 0,0,0,255
> > >> 174: 0,0,0,255
> > >> 175: 0,0,0,255
> > >> 176: 0,0,0,255
> > >> 177: 0,0,0,255
> > >> 178: 0,0,0,255
> > >> 179: 0,0,0,255
> > >> 180: 0,0,0,255
> > >> 181: 0,0,0,255
> > >> 182: 0,0,0,255
> > >> 183: 0,0,0,255
> > >> 184: 0,0,0,255
> > >> 185: 0,0,0,255
> > >> 186: 0,0,0,255
> > >> 187: 0,0,0,255
> > >> 188: 0,0,0,255
> > >> 189: 0,0,0,255
> > >> 190: 0,0,0,255
> > >> 191: 0,0,0,255
> > >> 192: 0,0,0,255
> > >> 193: 0,0,0,255
> > >> 194: 0,0,0,255
> > >> 195: 0,0,0,255
> > >> 196: 0,0,0,255
> > >> 197: 0,0,0,255
> > >> 198: 0,0,0,255
> > >> 199: 0,0,0,255
> > >> 200: 0,0,0,255
> > >> 201: 0,0,0,255
> > >> 202: 0,0,0,255
> > >> 203: 0,0,0,255
> > >> 204: 0,0,0,255
> > >> 205: 0,0,0,255
> > >> 206: 0,0,0,255
> > >> 207: 0,0,0,255
> > >> 208: 0,0,0,255
> > >> 209: 0,0,0,255
> > >> 210: 0,0,0,255
> > >> 211: 0,0,0,255
> > >> 212: 0,0,0,255
> > >> 213: 0,0,0,255
> > >> 214: 0,0,0,255
> > >> 215: 0,0,0,255
> > >> 216: 0,0,0,255
> > >> 217: 0,0,0,255
> > >> 218: 0,0,0,255
> > >> 219: 0,0,0,255
> > >> 220: 0,0,0,255
> > >> 221: 0,0,0,255
> > >> 222: 0,0,0,255
> > >> 223: 0,0,0,255
> > >> 224: 0,0,0,255
> > >> 225: 0,0,0,255
> > >> 226: 0,0,0,255
> > >> 227: 0,0,0,255
> > >> 228: 0,0,0,255
> > >> 229: 0,0,0,255
> > >> 230: 0,0,0,255
> > >> 231: 0,0,0,255
> > >> 232: 0,0,0,255
> > >> 233: 0,0,0,255
> > >> 234: 0,0,0,255
> > >> 235: 0,0,0,255
> > >> 236: 0,0,0,255
> > >> 237: 0,0,0,255
> > >> 238: 0,0,0,255
> > >> 239: 0,0,0,255
> > >> 240: 0,0,0,255
> > >> 241: 0,0,0,255
> > >> 242: 0,0,0,255
> > >> 243: 0,0,0,255
> > >> 244: 0,0,0,255
> > >> 245: 0,0,0,255
> > >> 246: 0,0,0,255
> > >> 247: 0,0,0,255
> > >> 248: 0,0,0,255
> > >> 249: 0,0,0,255
> > >> 250: 0,0,0,255
> > >> 251: 0,0,0,255
> > >> 252: 0,0,0,255
> > >> 253: 0,0,0,255
> > >> 254: 0,0,0,255
> > >> 255: 0,0,0,255
> > >> _______________________________________________
> > >> Qgis-user mailing list
> > >> Qgis-user at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
> > > belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110429/134612c8/attachment.html>
