[Qgis-user] bug?
Saber Razmjooei
razmjooeis at faunalia.co.uk
Wed Aug 3 03:32:01 PDT 2011
Here is a nicer tool from GIS-Lab:
http://gis-lab.info/qa/extract-values-rasters.html
(make sure you hit translate on top of the page from russian to english)
According to my test (almost 300,000 points on a 25 metre terrain) it
takes 20x less compared with the point sampling tool.
Some of other benefits:
- It can directly outputs to csv without adding it to dbf (that's what
you need I guess)
- Multiple rasters
- Shell based so you can write lots of scripts
Let us know if you have problems installing or using the tool.
Cheers
Saber
> Never sure where to send in bugs.
> Getting message "Export to vector file failed. Error: creation of data
> source failed (OGR error:)" when trying to save as .csv from a shapefile
> layer.
> Exporting to csv has worked before but just suddenly stopped working half
> way through a session when it did work with other layers earlier in the
> session. Have tried restarting qgis and recreating the shapefile (the
> file is produced from a set of points getting the underlying raster data
> for their positions using the point sampling tool) from scratch or
> reloading it but still get error although the error message is sometimes a
> little different.
> Am using qgis 1.8.0 (a21e1db) on windowsXP.
> The Open University is incorporated by Royal Charter (RC 000391), an
> exempt charity in England & Wales and a charity registered in Scotland (SC
> 038302).
> Qgis-user mailing list
