[Qgis-user] converting espg 4326
Alex Mandel
tech_dev at wildintellect.com
Thu Dec 1 00:48:36 PST 2011
I'm going to take a guess that you are asking if QGIS can create a prj
file that contains the projection information so that other programs
loading the shapefile can also read it. If that's the case I believe the
Vector->Data Management->Define Projection tool is what you're looking for.
Thanks,
Alex
On 12/01/2011 12:42 AM, steve sgalowski wrote:
> ty for your help andreas , but the program i have on my pda , does not
> accept this type of shap file espg 4326 , but it accepts shape files
> from cloud made but only some
> Stephen
> On 01/12/2011, Andreas Neumann<a.neumann at carto.net> wrote:
>> hm - what do you mean by that? EPSG 4326 is just one projection format
>> (like thousands of other projections). All shapefile readers should be
>> able to deal with it.
>> In QGIS, when you save to a Shapefiles you can even select the target
>> projection and it will automatically project the data for you.
>> Hope this helps,
>> Andreas
>> On Thu, 1 Dec 2011 18:31:10 +1000, steve sgalowski wrote:
>>> is there away to convert espg 4326 to standard shp files , that
>>> programs can use ?
