[Qgis-user] Qgis-web-client: apache config
Arif Arham
arhamilis at gmail.com
Mon Dec 5 17:12:40 PST 2011
Understood. Thanks!
You know what? I skip those steps for now just to see how my map looks in
the new qgis-web-client, and found some thing new! What I did was:
1. copying GlobalOptions.js.templ-4326 to GlobalOptions.js;
2. setting var serverAndCGI into "
http://localhost/cgi-bin/qgis_mapserv.fcgi"; and
3. displaying my map at
http://localhost/qgis-web-client/site/qgiswebclient.html?map=/home/arif/mymap/test.qgs
4. here is the best thing: searching is working! It uses Geonames
database (isn't?) to search any places.
-Arif
___________________________
KhazanahArham.wordpress.com <http://khazanaharham.wordpress.com>
On Mon, Dec 5, 2011 at 5:37 PM, Mathias Walker <mwa at sourcepole.ch> wrote:
> > I try to install the new update of Qgis-web-client. However, at "For the
> > Terminally Lazy", after reloading the Apache I found this error:
> > Syntax error on line 38 of
> > /etc/apache2/sites-enabled/qgis-web-client.conf:
> > Invalid command 'RewriteCond', perhaps misspelled or defined by
> > a module not included in the server configuration
> > Action 'configtest' failed.
> > The Apache error log may have more information.
> > ...fail!
> > This is what in line 38:
> > RewriteCond %{QUERY_STRING} ^(?:.*)query=samplesearch&*(?:.*)$
> > Is it okey to ignore it?
> The RewriteCond is optionally used for the search panel of the QGIS web-
> client. The RewriteRules are used for nicer URLs to the QGIS maps and web-
> client files.
> You have to enable the Apache 'mod_rewrite' module on your system, so it
> can
> use the 'RewriteCond' and 'RewriteRule' commands.
> Best regards
> Mathias Walker
> Sourcepole - Linux & Open Source Solutions
> Churerstrasse 22, 8808 Pfäffikon SZ, Switzerland
> Tel: 044 440 77 11 Fax: 044 440 77 12
> mwa at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111206/f93ab6be/attachment.html>
