[Qgis-user] Re: Install QGIS server on Ubuntu
Daniel.Gnerre at vevey.ch Daniel.Gnerre at vevey.ch
Tue Dec 13 07:47:31 PST 2011
YEEEES Marco, thank you very much, it works fine now :O)) !!
Kind regards.
Daniel
De :    Marco Hugentobler <marco.hugentobler at sourcepole.ch>
A :     Daniel.Gnerre at vevey.ch
Cc :    qgis-user at lists.osgeo.org
Date :  13.12.2011 16:44
Objet : Re: [Qgis-user] Re: Install QGIS server on Ubuntu
Hi Daniel
In the wms connection settings of QGIS (client) , select 'Ignore GetMap
url' and 'Ignore GetFeatureInfo url'.
Regards,
Marco
On 13.12.2011 16:30, Daniel.Gnerre at vevey.ch wrote:
Hello,
I finally installed qgis-mapserver using Ubuntu "Package Manager" and
Natty version instead of Oneiric...
Now I've set up a WMS service :
- Configured Apache with a scriptalias : http://localhost/qgis/ points on
/usr/lib/cgi-bin/qgis_mapserv.fcgi
- Created a small qgs project /home/gnerred/qgis/test.qgs containing one
shapefile /home/data/cadastre/cs_batiments.shp
- The GetCapabilities responds well :O) !
- But when I try to see the map result opening the WMS service in QGIS, I
get a blank map... and no getmap request is logged in Apache logs, only
the getcapabilities requests are logged. I use the URL
http://localhost/qgis/qgis_mapserver.fcgi?MAP=/home/gnerred/qgis/test.qgs
Any idea of the problem ? I think I'm not so far !
Thanks a lot !
Daniel
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111213/deba3e41/attachment.html>
