[Qgis-user] Re: Install QGIS server on Ubuntu
Anita Graser anitagraser at gmx.at
Tue Dec 13 07:49:34 PST 2011
Hi Marco,
Could you explain what those two options do and when they should be used?
Are there any rules or is it always trial-and-error?
Regards,
Anita
On Tue, Dec 13, 2011 at 4:43 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
>  Hi Daniel
> In the wms connection settings of QGIS (client) , select 'Ignore GetMap
> url' and 'Ignore GetFeatureInfo url'.
> Regards,
> Marco
> On 13.12.2011 16:30, Daniel.Gnerre at vevey.ch wrote:
> Hello,
> I finally installed qgis-mapserver using Ubuntu "Package Manager" and
> Natty version instead of Oneiric...
> Now I've set up a WMS service :
> - Configured Apache with a scriptalias : http://localhost/qgis/ points on
> /usr/lib/cgi-bin/qgis_mapserv.fcgi
> - Created a small qgs project /home/gnerred/qgis/test.qgs containing one
> shapefile /home/data/cadastre/cs_batiments.shp
> - The GetCapabilities responds well :O) !
> - But when I try to see the map result opening the WMS service in QGIS, I
> get a blank map... and no getmap request is logged in Apache logs, only the
> getcapabilities requests are logged. I use the URL
> http://localhost/qgis/qgis_mapserver.fcgi?MAP=/home/gnerred/qgis/test.qgs
> Any idea of the problem ? I think I'm not so far !
> Thanks a lot !
> Daniel
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111213/7d56f2b4/attachment.html>
