[Qgis-user] Re: Install QGIS server on Ubuntu
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Dec 13 08:05:59 PST 2011
Hi Anita
In the GetCapabilities response, a WMS server gives back the urls for
GetMap and GetFeatureInfo (they could be different to the url used for
GetCapabilities). However, in most cases, the base url is the same as
for GetCapabilities. Even worse, in most cases, the advertised urls for
GetMap and GetFeatureInfo are wrong. QGIS server generates those urls
from the cgi environment variables, other servers rely on admin
configuration.
In most cases, it is appropriate to select the two options (we should
probably select them by default).
Regards,
Marco
On 13.12.2011 16:49, Anita Graser wrote:
> Hi Marco,
> Could you explain what those two options do and when they should be
> used? Are there any rules or is it always trial-and-error?
> Regards,
> Anita
> On Tue, Dec 13, 2011 at 4:43 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>> wrote:
> Hi Daniel
> In the wms connection settings of QGIS (client) , select 'Ignore
> GetMap url' and 'Ignore GetFeatureInfo url'.
> Regards,
> Marco
> On 13.12.2011 16:30, Daniel.Gnerre at vevey.ch
> <mailto:Daniel.Gnerre at vevey.ch> wrote:
>> Hello,
>> I finally installed qgis-mapserver using Ubuntu "Package Manager"
>> and Natty version instead of Oneiric...
>> Now I've set up a WMS service :
>> - Configured Apache with a scriptalias :
>> http://localhost/qgis/points on /usr/lib/cgi-bin/qgis_mapserv.fcgi
>> - Created a small qgs project /home/gnerred/qgis/test.qgs
>> containing one shapefile /home/data/cadastre/cs_batiments.shp
>> - The GetCapabilities responds well :O) !
>> - But when I try to see the map result opening the WMS service in
>> QGIS, I get a blank map... and no getmap request is logged in
>> Apache logs, only the getcapabilities requests are logged. I use
>> the URL
>> http://localhost/qgis/qgis_mapserver.fcgi?MAP=/home/gnerred/qgis/test.qgs
>> Any idea of the problem ? I think I'm not so far !
>> Thanks a lot !
>> Daniel
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111213/ac8c8c35/attachment.html>
