[Qgis-user] Re: new xytools plugin: now open and save simple Excel files
Arif Arham
arhamilis at gmail.com
Sat Dec 17 08:55:29 PST 2011
I work on Ubuntu 11.10, QGIS 1.7.3
----start-------
An error has occured while executing Python code:
File "/home/areev/.qgis/python/plugins/xytools/xytools.py", line 188, in
excelSave
from providers import excel
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 283, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/home/areev/.qgis/python/plugins/xytools/providers/excel.py", line
1, in
import xlwt
_import
ImportError: No module named xlwt
Python version:
2.7.2+ (default, Oct 4 2011, 20:29:37)
[GCC 4.6.1]
QGIS version:
1.7.3-Wroclaw Wroclaw, exported
Python path: ['/usr/share/qgis/python', '/home/areev/.qgis/python',
'/home/areev/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-couch',
'/usr/lib/python2.7/dist-packages/ubuntuone-installer',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
'/home/areev/.qgis/python/plugins/openlayersov/logic',
'/home/areev/.qgis/python/plugins/openlayersov/gui',
'/usr/share/qgis/python/plugins/fTools/tools']
------end-----------
On Sat, Dec 17, 2011 at 3:14 PM, Richard Duivenvoorde
<rdmailings at duif.net>wrote:
> On 2011-12-17 00:57, Arif Arham wrote:
> > I got a problem when executing "Save attribute table as Excel file".
> > In fact, several plugins end with this kind of errors. Is it python's
> > bug or plugin's bug?
> can you give more info? In this mail I cannot see the actual message
> also not here:
> http://osgeo-org.1803224.n2.nabble.com/new-xytools-plugin-now-open-and-save-simple-Excel-files-td7098439.html#a7101831
> You can sent me a screendump or copy the full message from the error
> window.
> Otherwise, let me know which OS and Qgis version you use, and/or sent me
> the data that is throwing the error.
> Regards,
> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111217/07854b4d/attachment.html>
