[Qgis-user] Re: new xytools plugin: now open and save simple Excel files
Richard Duivenvoorde
richard at duif.net
Sat Dec 17 09:49:10 PST 2011
The next version will not show you this python error anymore, but a
message that you have to install the python libs xlrd and xlwr...
On Ubuntu
just do
sudo apt-get install xlwt xlrd
this will install the nessecary python libraries which are needed to do
the excel reading and writing
(and you are invited to read the help from the xytools context menu :-) )
Regards,
Richard
On 2011-12-17 17:55, Arif Arham wrote:
> I work on Ubuntu 11.10, QGIS 1.7.3
> ----start-------
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/areev/.qgis/python/plugins/xytools/xytools.py", line 188,
> in excelSave
> from providers import excel
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 283, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/home/areev/.qgis/python/plugins/xytools/providers/excel.py",
> line 1, in
> import xlwt
> _import
> ImportError: No module named xlwt
> Python version:
> 2.7.2+ (default, Oct 4 2011, 20:29:37)
> [GCC 4.6.1]
> QGIS version:
> 1.7.3-Wroclaw Wroclaw, exported
> Python path: ['/usr/share/qgis/python', '/home/areev/.qgis/python',
> '/home/areev/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/home/areev/.qgis/python/plugins/openlayersov/logic',
> '/home/areev/.qgis/python/plugins/openlayersov/gui',
> '/usr/share/qgis/python/plugins/fTools/tools']
> ------end-----------
> On Sat, Dec 17, 2011 at 3:14 PM, Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> On 2011-12-17 00:57, Arif Arham wrote:
> > I got a problem when executing "Save attribute table as Excel file".
> > In fact, several plugins end with this kind of errors. Is it python's
> > bug or plugin's bug?
> can you give more info? In this mail I cannot see the actual message
> also not here:
> http://osgeo-org.1803224.n2.nabble.com/new-xytools-plugin-now-open-and-save-simple-Excel-files-td7098439.html#a7101831
> You can sent me a screendump or copy the full message from the error
> window.
> Otherwise, let me know which OS and Qgis version you use, and/or sent me
> the data that is throwing the error.
> Regards,
> Richard
