[Qgis-user] files dwg in QGIS
Brad Nesom
gisbradokla at live.com
Mon Dec 19 11:50:46 PST 2011
I believe dwg is supported in the fdo library.
I have often wondered what kept the qgis dev from using fdo?
http://fdo.osgeo.org/OSProviderOverviews.html
I do see some overlap but adding eliminating providers is a simple task
(that even I can do).
On Mon, Dec 19, 2011 at 1:14 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le lundi 19 décembre 2011 13:11:12, Andreas Neumann a écrit :
> > assuming you want to open DWG files in GIS?
> > Currently it is not possible to read or write DWG files. QGIS uses OGR
> > to read/write vector data and DWG is not on the list of supported
> > formats. There is initial support for dxf (but with some issues).
> > You can consider sponsoring the development of a DWG driver in OGR if
> > you are interested in reading/writing these files. It would probably be
> > based on other existing libraries.
> There is a new driver for DWG based on the Open Design Alliance Teigha
> Libraries (not FOSS AFAIK) in GDAL 1.9.0dev trunk. I don't know why it is
> not
> advertized on the OGR formats page, maybe beacause its status is still a
> bit
> experimental. Perhaps FrankW could confirm.
> > Andreas
> > On Mon, 19 Dec 2011 11:28:42 +0100, livreri wrote:
> > > Salve!
> > > Vorrei vedere dei files dwg in QGIS 1.7!
> > > Come posso fare?
> > > Grazie a tutti
> > > S. Livreri Console
> > > Hello!
> > > I wish to see some DWG files in QGIS 1.7!
> > > How can I do it?
> > > Thank you all
> > > S. Livreri Console
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111219/00e2a061/attachment.html>
