[Qgis-user] files dwg in QGIS
    Even Rouault
    even.rouault at mines-paris.org
    Mon Dec 19 12:31:13 PST 2011
Le lundi 19 décembre 2011 21:23:38, Andreas Neumann a écrit :
> no - unfortunately FDO does not support DWG files --> see
> http://themapguyde.blogspot.com/2011/12/my-2010-mapguidefdo-wishlist-revisi
> ted.html (item 6)
> I guess Autodesk regards DWG as their "crown jewels" and therefore does
> not support OS developement around DWG.
> There is a FDO/OGR bridge, but unless FDO has some advantages over OGR -
> why should one use it? DWG support in FDO would be one reason to look
> into FDO.
A few weeks ago, I wanted to try FDO to see what value it could bring, and I
couldn't manage to build it under Linux. It is supposed to be possible, but
following the build instructions was just too complicated for me. Or perhaps
because I didn't want to follow the build instructions that want to make
/usr/local user writable...
> Andreas
> On 12/19/2011 08:50 PM, Brad Nesom wrote:
> > I believe dwg is supported in the fdo library.
> > I have often wondered what kept the qgis dev from using fdo?
> > http://fdo.osgeo.org/OSProviderOverviews.html
> > I do see some overlap but adding eliminating providers is a simple task
> > (that even I can do).
> > On Mon, Dec 19, 2011 at 1:14 PM, Even Rouault
> > <even.rouault at mines-paris.org>wrote:
> >> Le lundi 19 décembre 2011 13:11:12, Andreas Neumann a écrit :
> >>>  assuming you want to open DWG files in GIS?
> >>>  Currently it is not possible to read or write DWG files. QGIS uses OGR
> >>>  to read/write vector data and DWG is not on the list of supported
> >>>  formats. There is initial support for dxf (but with some issues).
> >>>  You can consider sponsoring the development of a DWG driver in OGR if
> >>>  you are interested in reading/writing these files. It would probably
> >>>  be based on other existing libraries.
> >> There is a new driver for DWG based on the Open Design Alliance Teigha
> >> Libraries (not FOSS AFAIK) in GDAL 1.9.0dev trunk. I don't know why it
> >> is not
> >> advertized on the OGR formats page, maybe beacause its status is still a
> >> bit
> >> experimental. Perhaps FrankW could confirm.
> >>>  Andreas
> >>>  On Mon, 19 Dec 2011 11:28:42 +0100, livreri wrote:
> >>>> Salve!
> >>>> Vorrei vedere dei files dwg in QGIS 1.7!
> >>>> Come posso fare?
> >>>> Grazie a tutti
> >>>> S. Livreri Console
> >>>> Hello!
> >>>> I wish to see some DWG files in QGIS 1.7!
> >>>> How can I do it?
> >>>> Thank you all
> >>>> S. Livreri Console
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
