[Qgis-user] question for csv import with color
Richard Duivenvoorde rdmailings at duif.net
Sat Dec 24 05:32:11 PST 2011
Richard Duivenvoorde wrote:
> henry cui wrote:
>> hi Richard,
>>     thanks for reply.
>>     The way of Categorized Style surely make the dot seem
>> different.But I hope to put all thing predefined in that csv file,because
>> I need output the csv from another software and then import qgis to
>> get the glance of whole state of these dots.This operations will be a
>> little bit more frequent and the dot actually has three or more
>> different states,so I want to simply the operations as much as possible.
>> I guess put everything in that a single file is a simple way but i
>> dont't know wether it is feasible in QGIS?
ah, and to make it scriptable: (don't know on which OS you are), but if
you open QGIS from commandline you can even give it the name of the
project file, and it will open that project at once (see 'qgis --help'):
  qgis /home/richard/temp/csvtest.qgs
In that way you can let your script do your csv export, and open the
data in QGIS in one click :-)
R
