[Qgis-user] R: Qgis-user Digest, Vol 70, Issue 58
davide.damato_1982 at libero.it davide.damato_1982 at libero.it
Wed Dec 28 00:50:44 PST 2011
You can try to copy prj file and rename the prj with the name of the shape that
you don't have prj.
It's a barbarian method, but often It's right.
GOOD LUCK
dave
>----Messaggio originale----
>Da: qgis-user-request at lists.osgeo.org
>Data: 28-dic-2011 9.46
>A: <qgis-user at lists.osgeo.org>
>Ogg: Qgis-user Digest, Vol 70, Issue 58
>Send Qgis-user mailing list submissions to
>To subscribe or unsubscribe via the World Wide Web, visit
>	http://lists.osgeo.org/mailman/listinfo/qgis-user
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
>	qgis-user-owner at lists.osgeo.org
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of Qgis-user digest..."
>Today's Topics:
>   1. RE: Hi everybody (Gerardo Jimenez)
>   2. RE: Hi everybody (Gerardo Jimenez)
>   3. Calculating Shrotes Route (Saqib Kazmi)
>   4. Startup failure - maybe a GTK issue? (Tony Bazeley)
>   5. question - chaging shapefile to GRASS vector layer
>      (Tilottama Ghosh)
>   6. Re: question - chaging shapefile to GRASS vector layer
>      (Giovanni Manghi)
>Message: 1
>Date: Tue, 27 Dec 2011 12:55:12 -0500
>From: Gerardo Jimenez <gejst5 at hotmail.com>
>Subject: RE: [Qgis-user] Hi everybody
>To: <qgis-user at lists.osgeo.org>
>Message-ID: <SNT119-W3485689C977611D1600D2795AF0 at phx.gbl>
>Content-Type: text/plain; charset="iso-8859-1"
>If you have a shape file it should have also a *.prj file. This file defines
the projection of your layer. By default, Qgis assumes that your data is a lat
lon wgs84 and coordinate units degrees. If you have your *.prj file try this
first
>Open QGis, load the layer select it and choose set project crs from layer
>If that does not do the trick try opening the prj file in a text editor and
try to identify your CRS (Coordinate Reference System). Then, in Qgis, after
loading your layer, Go to layer properties/General choose the specify button
and look for your crs in the "Projected Coordinate Systems" section. Do the
same at Settings/Project Properties/CRS Tab.
>Hope it helps
>Gerardo Jiménez Delgado
>Instituto de Investigaciones Antropológicas
>Universidad Nacional Autónoma de México
>Ciudad Universitaria s/n
>Coyoacan 04510
>Mexico City
>Mexico
>56 22 95 16
>Date: Tue, 27 Dec 2011 15:09:00 +0000
>From: giacomofontanelli at yahoo.it
>To: qgis-user at lists.osgeo.org
>Subject: [Qgis-user] Hi everybody
>Hi, I'm Giacomo Fontanellin from Florence, Italy.I'm a PhD for University of
Basilicata, I work on remote sensing of environment.I'm quite new with QGis,
buti I like it, cause it's very easy to use and user-friendly. This is my
problem: I've got many shape file in a project, each of those with different
projections, but I still can visualize the polygons in the right position. The
spatial extension of the files is almost the same and is defined in meters:
example: xMin, yMin 1714882.75,4845790.12 : xMax,yMax 1735233.69,4861856.86.
>Unfortunally I've got a layer with the spatial extension defined in degrees:
xMin, yMin 10.94,43.7388 : xMax,yMax 11.7543,43.9773, and I can't visualize it
in the correct location. How can I change the extension of the files from
degrees to meters and viceversa? Thank you very much and sorry for my english
>_______________________________________________
>Qgis-user at lists.osgeo.org
>-------------- next part --------------
>An HTML attachment was scrubbed...
>URL: http://lists.osgeo.org/pipermail/qgis-
user/attachments/20111227/a5188be3/attachment-0001.html
>Message: 2
>Date: Tue, 27 Dec 2011 13:00:51 -0500
>Message-ID: <SNT119-W1214BD41E15B0BF342CD7C95AF0 at phx.gbl>
>Sorry,
> if you want all your layers in the same crs you have to reproject your data.
This is easy, load a layer, select it and choose save as, there you have to
define a new name and the crs of your choice. One thing, in order that the
reprojection could succeed  both the project and the layer must have the same
crs (see my previous post)
>Coyoacan 04510
>Mexico City
>Mexico
>56 22 95 16
>From: gejst5 at hotmail.com
first
>Hope it helps
>Coyoacan 04510
>Mexico City
>Mexico
>56 22 95 16
user/attachments/20111227/adda3b30/attachment-0001.html
>Message: 3
>Date: Wed, 28 Dec 2011 00:04:23 +0500
>From: Saqib Kazmi <saqibkazmi at live.com>
>Subject: [Qgis-user] Calculating Shrotes Route
>Message-ID: <COL122-W645B792960E1C5E971EB54BFAF0 at phx.gbl>
>Hi!!! Howz doing all of u??? Dear Members can any1 provide me the QGIS query
through which i can calculate a shortest distance between two points??
>Actually i have a line shape file of BUS Routes and a Point Shape file of BUS
Stops, now i want to query in such a way that i assign the bus steps name qgis
will return me the shortest path(which will be a line shape file)... Any idea
about this???
>With Best Regards
>Saqib Kazmi
user/attachments/20111228/6d6c80c2/attachment-0001.html
>Message: 4
>Date: Wed, 28 Dec 2011 17:31:56 +1030
>From: Tony Bazeley <tbag at internode.on.net>
>Subject: [Qgis-user] Startup failure - maybe a GTK issue?
>Message-ID: <1325055716.2233.3.camel at muscatelle>
>Content-Type: text/plain; charset="utf-8"
>Hi,
>I've been running qgis 1.7.3 successfully under 32 bit Ubuntu Oneiric,
>and am in the process of upgrading to a new machine with the same OS but
>64 bit.
>Qgis produces the tips/flash screen and then fails - running from the
>terminal yields the output shown below.
>I've reinstalled QGIS using synaptic, and have also allowed the
>rebuilding of qgis.db on startup
>I can't find any references on the Bugs page, or on the wider web, and I
>am finding it difficult to sort my way through the maze of dependencies.
>Any pointers as to how to proceed would be much appreciated.
>TIA
>Tony
>xxx:~$ qgis
>Warning: loading of qgis translation failed
>[/usr/share/qgis/i18n//qgis_en_AU]
>Warning: loading of qt translation failed
>[/usr/share/qt4/translations/qt_en_AU]
>Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
>tracking action "Project Properties..." under id 104
>tracking action "Options..." under id 108
>tracking action "Snapping Options..." under id 109
>tracking action "Configure shortcuts..." under id 107
>tracking action "Style manager..." under id 106
>tracking action "Custom CRS..." under id 105
>Python support ENABLED :-)
>Loaded : qgsAffine (package: qgsAffine)
>Loaded : Geoprocessing (package: geoprocessing)
>Loaded : fTools (package: fTools)
>Loaded : PostGPS (package: postgps)
>Loaded : Html Image Map Plugin (package: imagemap_plugin)
>Loaded : Rectangles, Ovals, Diamonds (package: rectovaldiams)
>Loaded : GdalTools (package: GdalTools)
>Loaded : Metaedit (package: metaedit)
>Loaded : manageR (package: manageR)
>Loaded : Plugin Installer (package: plugin_installer)
>Loaded : OpenStreetMap plugin (package: osm)
user/attachments/20111228/b86f4609/attachment-0001.html
>Message: 5
>Date: Wed, 28 Dec 2011 13:17:46 +0530
>From: Tilottama Ghosh <waggymaggy at gmail.com>
>Subject: [Qgis-user] question - chaging shapefile to GRASS vector
>	layer
>Message-ID:
>	<CAAztfOnsHjF9a=Gooj+xeP-sRhDm+HD8ExMkv6pKmY2ykEVVFw at mail.gmail.com>
>Dear Quantum GIS users,
>So, something weird is happening when I am converting a polygon shapefile
>to a GRASS vector layer. Several duplicates of one polygon name is being
>created,but when I highlight the duplicates, only one them actually has the
>polygon shape stored in it. The data for all the duplicate polygon names
>are also repeated. Has someone faced a similar problem? If yes, can you
>please let me know how to correct it? I will look forward to some good
>advise.
>Thanks in advance and WISH YOU A VERY HAPPY NEW YEAR!
>Cheers,
>Tilottama
user/attachments/20111228/c3864a3a/attachment-0001.html
>Message: 6
>Date: Wed, 28 Dec 2011 08:45:46 +0000
>From: Giovanni Manghi <giovanni.manghi at faunalia.pt>
>Subject: Re: [Qgis-user] question - chaging shapefile to GRASS vector
>	layer
>To: Tilottama Ghosh <waggymaggy at gmail.com>
>Cc: qgis-user at lists.osgeo.org
>Message-ID: <1325061946.2239.66.camel at sibirica>
>Content-Type: text/plain; charset="UTF-8"
>http://grass.osgeo.org/wiki/QGIS_GRASS_Cookbook
>"Notes for polygons:
>    polygon_0 are the holes
>    polygon_1 are the areas with one centroid
>    polygon_2 are the area with two centroids (overlapped areas)"
>> shapefile to a GRASS vector layer. Several duplicates of one polygon
>> name is being created,but when I highlight the duplicates, only one
>> them actually has the polygon shape stored in it. The data for all the
>> duplicate polygon names are also repeated. Has someone faced a similar
>> problem? If yes, can you please let me know how to correct it? I will
>> look forward to some good advise.
>> Cheers,
>> Tilottama
>End of Qgis-user Digest, Vol 70, Issue 58
