[Qgis-user] Re:changing shapefile to grass vector layer
Tilottama Ghosh waggymaggy at gmail.com
Wed Dec 28 03:29:17 PST 2011
Hi again,
Thanks for your response Giovanni. I understood what the three polygons
that were created means. However, the problem is in the repetitive names of
the same district and its values in the 1_polygon shapefile. PFA an example
excel sheet. There must have been some problems in the initial shapefile
itself. However, if someone has come across the same problem and can
suggest some ways of correcting this, it will be very helpful.
Thanks,
Tilottama
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111228/10393e4c/attachment.html>
