[Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
Markus Weidenbach landconsult at freenet.de
Thu Feb 3 10:19:02 PST 2011
on WIN 7 you have to copy the *.dll to C:\OSGeo4W\apps\qgis\plugins,
then start QGIS 1.6 and activate the plugin under the menu
extensions/manage extensions.
I am using WIN7, 64bit and QGIS 1.6 and it works. The extension is
limited to some OTB functions, I hope more functionalities will be
implemented on a later version :-) .
Regards,
Markus
Dr. Markus Weidenbach
*landConsult.de*
Geographical Information Management
and Environmental Planning
D-77773 Schenkenzell
Germany
e.mail see: http://landConsult.de
Am 27.01.2011 13:37, schrieb M.E.Dodd:
> Thanks for this.  I've tried a few different ways as suggested on that page but not sure I am doing it right as nothing is obviously appearing, at the moment am trying:
> "OTB module is available as a separate file , the installation is reduced to the unpacking and transfer dll-library in the directory of extensions installed QGIS."
> Have downloaded the .dll file and put it in the directory C:\OSGeo4W\bin but not sure if this is correct, should it be in one of the other subdirectories as I can't find one called 'extensions'.
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: 26 January 2011 20:51
> To: M.E.Dodd
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
> On Wed, 2011-01-26 at 17:01 +0000, M.E.Dodd wrote:
>> I can find their website and the full Monteverdi program but can't
>> work out how to install the qgis plugin, any suggestions?
> Gis-Lab packaged the plugin for windows
> http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http://gis-lab.info/blog/2010-11/otb-plugin-qgis/
> cheers
> -- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110203/add87f28/attachment.html>
