[Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
Markus Weidenbach
landconsult at freenet.de
Fri Feb 4 10:32:19 PST 2011
Yes, I carried out KMeans, Hillshade and SOM clustering without any
problems (didn“t test the other functions yet)
M.
Am 04.02.2011 15:14, schrieb M.E.Dodd:
> Does it actually carry out the functions as when I tried it the plugin
> started up fine but when asking it to perform the task it crashed
> qgis. Qgis 1.6 windowsxp 32bit.
> *From:*Markus Weidenbach [mailto:landconsult at freenet.de]
> *Sent:* 03 February 2011 18:19
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Is there a way of installing the qgis
> Hi,
> on WIN 7 you have to copy the *.dll to C:\OSGeo4W\apps\qgis\plugins,
> then start QGIS 1.6 and activate the plugin under the menu
> extensions/manage extensions.
> I am using WIN7, 64bit and QGIS 1.6 and it works. The extension is
> limited to some OTB functions, I hope more functionalities will be
> implemented on a later version :-) .
> Regards,
> Markus
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77773 Schenkenzell
> Germany
> e.mail see: http://landConsult.de
> Am 27.01.2011 13:37, schrieb M.E.Dodd:
> Thanks for this. I've tried a few different ways as suggested on that page but not sure I am doing it right as nothing is obviously appearing, at the moment am trying:
> "OTB module is available as a separate file , the installation is reduced to the unpacking and transfer dll-library in the directory of extensions installed QGIS."
> Have downloaded the .dll file and put it in the directory C:\OSGeo4W\bin but not sure if this is correct, should it be in one of the other subdirectories as I can't find one called 'extensions'.
> -----Original Message-----
> From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
> Sent: 26 January 2011 20:51
> To: M.E.Dodd
> Cc:qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Is there a way of installing the qgis plugin for ORFEO Toolbox (OTB)?
> On Wed, 2011-01-26 at 17:01 +0000, M.E.Dodd wrote:
>> I can find their website and the full Monteverdi program but can't
>> work out how to install the qgis plugin, any suggestions?
> Gis-Lab packaged the plugin for windows
> http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http://gis-lab.info/blog/2010-11/otb-plugin-qgis/ <http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http://gis-lab.info/blog/2010-11/otb-plugin-qgis/>
> cheers
> -- Giovanni --
> The Open University is incorporated by Royal Charter (RC 000391), an
> exempt charity in England & Wales and a charity registered in Scotland
> (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110204/87e950e2/attachment.html>
