[Qgis-user] compiling from source, how to build qgis-mapserver qgis_map_serv.fcgi ?
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu Feb 10 07:02:49 PST 2011
Hi Oliver
You need to enable the compilation of the server in the cmake configuration:
cd <sourcedir>/build
ccmake ..
then set WITH_MAPSERVER to ON
Regards,
Marco
Am Donnerstag, 10. Februar 2011, um 15.02:52 schrieb Oliver Christen:
> dear list
> Im trying to compile qgis from source in order to generate the
> qgis-mapserver qgis_map_serv.fcgi file.
> I followed the documentation on http://www.qgis.org/wiki/Installation_Guide
> and on http://karlinapp.ethz.ch/qgis_wms/documentation/index.html
> I can build a working qgis both on Linux (ubuntu) and on Windows, but I
> must be missing something as the .fcgi file is never generated.
> The Qgis-mapserver documentation say I need the FCGI library but is there
> some configuration somewhere I need to change to instruct the build to use
> that library in order to generate the .fcgi file?
> I know there is a qgis-mapserver debian package available, I installed it
> and it works fine, but I would really like to be able to build the .fcgi
> file
> Thanks a lot in advance
> Regards
> Oliver Christen
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
