[Qgis-user] MMQGIS plugin - Color Map error
Jürgen E. Fischer jef at norbit.de
Mon Feb 14 01:55:24 PST 2011
Hi Cameron,
On Mon, 14. Feb 2011 at 01:46:43 -0800, Cameron Munro wrote:
> Thanks for your suggestion. I assume you to mean a blank ascii file will suffice
> (I can find no mmqgis.qml as part of the std plugin installation). I've tried
> putting such an empty file in \.qgis\python\plugins\mmqgis\tmp and a few other
> spots but without success. Is there something obvious I'm missing, or perhaps
> somewhere in the tree I should have such an empty file?
No, just an empty directory tmp in the root of your current drive (eg. C:\tmp)
- without it creating a file /tmp/mmqgis.qml won't work.
/tmp is the standard directory for temporary files on Unix.  So this is just an
ugly workaround.  The plugin should create the temporary file in a portable way
(e.g. with Qt's QTemporaryFile or Python's tempfile).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
