[Qgis-user] MMQGIS plugin - Color Map error
Noli Sicad
nsicad at gmail.com
Mon Feb 14 02:07:28 PST 2011
Hi Cameron,
I am using Ubuntu 10.04 (linux). I don't have problem with Color Map.
Try using a different shapefile and see what happen. Or changing the
attribute column.
Noli
On 2/14/11, Cameron Munro <cameron.munro at yahoo.com> wrote:
> Hi Noli
> Thanks for your suggestion. I assume you to mean a blank ascii file will
> suffice
> (I can find no mmqgis.qml as part of the std plugin installation). I've
> tried
> putting such an empty file in \.qgis\python\plugins\mmqgis\tmp and a few
> other
> spots but without success. Is there something obvious I'm missing, or
> perhaps
> somewhere in the tree I should have such an empty file?
> Cheers
> Cameron.
> ----- Original Message ----
> From: Noli Sicad <nsicad at gmail.com>
> To: Cameron Munro <cameron.munro at yahoo.com>
> Cc: qgis-user at lists.osgeo.org
> Sent: Sun, February 13, 2011 10:06:10 PM
> Subject: Re: [Qgis-user] MMQGIS plugin - Color Map error
> Hi Cameron,
> Try to create a "tmp" directory, then save "mmqgis.qml" file first.
> '/tmp/mmqgis.qml'
> Then, this error will go away, I think.
> I have similar problem with mmqgis before.
> Noli
> On 2/13/11, Cameron Munro <cameron.munro at yahoo.com> wrote:
>> I'm running QGIS1.6 and Win7. The mmqgis plugin package is terrific,
>> except
>> I
>> get an error when I try color map (below), seems not to be able to find
>> mmqgis.qml. Does anyone else experience this issue, and if so is there a
>> solution/workaround? I've tried reinstalling the plugin without success,
>> and
>> have observed the same issue trying it in QGIS1.5.
>> Cheers
>> Cameron.
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>> File "C:/Users/Cameron/.qgis/python/plugins\mmqgis\mmqgis_dialogs.py",
>> line
>> 292, in run
>> int(self.highcolor.palette().color(QPalette.Normal,
>> QPalette.Button).rgb()))
>> File "C:/Users/Cameron/.qgis/python/plugins\mmqgis\mmqgis_library.py",
>> line
>> 251, in mmqgis_set_color_map
>> outfile = open(temp_filename, 'w')
>> IOError: [Errno 2] No such file or directory: '/tmp/mmqgis.qml'
>> Python version:
>> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
>> <snip>
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
