[Qgis-user] "Select by location" - Problem
Frederick Löbig zerox at zeroxweb.de
Mon Feb 14 14:09:25 PST 2011
uh that's a good question... I'll check that in the office tomorrow...
Thank's for the fast response!
Best,Freddy
Frederick Löbig
Röderichstraße 59
60489 Frankfurt am Main
E:: Frederick.Loebig at grunsnid.de
P: +49 (0) 69 - 78 99 52 41
M: +49 (0) 174 - 70 89 296
Office:
euNetworks GmbH
Ludwig-Landmann-Straße 40560486 Frankfurt am MainP: +49 (0) 69 - 90 554 - 532
E: Frederick.Loebig at eunetworks.com
S: floebig
This email and any attachments may contain confidential and/or legally privileged information. If you are not the intended recipient, please delete the email without reading it and notify the sender.
> Date: Mon, 14 Feb 2011 17:29:20 +0000
> Subject: Re: [Qgis-user] "Select by location" - Problem
> From: carson.farmer at gmail.com
> To: zerox at zeroxweb.de
> CC: qgis-user at lists.osgeo.org
> Hi Freddy,
> Are your two layers using the same CRS? Even with 'on the fly
> projection' on, this tool will not find intersections unless they are
> in the same projection. In fact, all the vector menu tools follow this
> general 'rule'.
> Carson
> 2011/2/14 Frederick Löbig <zerox at zeroxweb.de>:
> > Hey there,
> > I want to use the "select by location" function to select buildings wich are
> > within a certain distance from a cable. I started by generating a buffer
> > around the line-parts. Now I want to use the function "select by location"
> > to select every building wich intersects with that buffer. But somehow, when
> > I hit "OK", the prograssbar starts to move to 100%, finishes, but doesn't
> > select anything.
> > I wanted to find out why that is so I created a new project, added some
> > points (shapefile), added a polygon (shapefile) and tried to select the
> > intersecting points, but with no success. Why is that?
> > This is what I did:
> > Select features in <points> that intersect features in <polygon>. Modify
> > current selection by creating new selection.
> > I also tried to flip polygon and points.
> > Can anybody help me with this please?
> > Best,
> > Freddy
> > Frederick Löbig
> > Röderichstraße 59
> > Office:
> > euNetworks GmbH
> > S: floebig
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation
> National University of Ireland, Maynooth,
> http://www.carsonfarmer.com/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110214/b18c061f/attachment.html>
